2004 Chevy Trailblazer coolant thermostat
CZIELINSKI
  • 2004 CHEVROLET TRAILBLAZER
  • 6 CYL
  • 103,000 MILES
I recently replaced the thermostat sensor for the check engine light to clear now its on for the coolant thermostat is there something I missed.
Do you
have the same problem?
Tuesday, January 13th, 2009 AT 5:39 PM
MMPRINCE4000
  • EXPERT
Did you change the coolant temp. Sensor, or the thermostat?
If the PCM sees that coolant temp is below thermostat regulating temp, it will set an error code.
This means the PCM sees coolant temp. At say 177 degrees, while it should be at 195.
This is caused by either the thermostat or the coolant temp. Sensor that is misreading the engine temp.
Wednesday, January 14th, 2009 AT 8:08 AM
Recommended Guides
