2004 Chevy Trailblazer
DONIGLAY
  • 2004 CHEVROLET TRAILBLAZER
Electrical problem
2004 Chevy Trailblazer 6 cyl Four Wheel Drive Automatic 4oooo miles
dashboard gauges don't work battery and brake indicaters stay lit new batt. Installed
Do you
have the same problem?
Wednesday, February 25th, 2009 AT 11:46 AM
DENNYP
  • EXPERT
First, make sure the battery cable ends are completly clean and free of any corrosion. Make sure they have a good connection at the battery. Check the fuse box under the driver side rear seat. Make sure there is no water or corrosion in the fuse box. If all is ok, you probably have a bad instrument cluster. You will need a Tech 2 scanner to see if you have communication with the cluster.
Wednesday, February 25th, 2009 AT 3:20 PM
Recommended Guides
