This might help. Found this bulletin. Some customers may comment that the blower motor is inoperative or continues to run after the vehicle has been shut off. These conditions may be caused by a blower motor control module failure. This failure may occur when the vehicle is operated in ambient temperature conditions of -23°C (-10°F) or below. Important: Replace the blower motor control module if the vehicle experienced a blower motor control module failure in extremely cold ambient temperature conditions.
Technicians are to replace the blower motor control module, also called the Linear Power Module (LPM). After replacement of the blower motor control module, the customer may notice a slightly higher than expected blower motor speed at any of the blower speed settings.
Try this it might help.
Tuesday, January 29th, 2008 AT 8:56 PM
