My transmission has no reverse can we fix it?
JOSE M LOPEZ2
  • 2005 CHEVROLET SILVERADO
  • 4.8L
  • V8
  • 150,000 MILES
My truck when put into reverse gear make loud screatching noise and metal clank
Sunday, May 1st, 2016 AT 7:33 AM
HMAC300
  • 48,601 POSTS
Check brakes all around it may be the brake squealers making noise.
Sunday, May 1st, 2016 AT 8:17 AM
HMAC300
  • 48,601 POSTS
Shoot thought it was something else. Have a trans guy check this out sounds like something may be broken in trans.
Sunday, May 1st, 2016 AT 8:18 AM
JOSE LOPEZ2
Yeah im taking it today I think the sun shell broke off inside
Saturday, May 7th, 2016 AT 5:55 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,904 POSTS
Let us know what you find out so it may help others
Saturday, May 7th, 2016 AT 7:38 AM
MYDLITE58
  • 8 POSTS
  • 2004 CHEVROLET SILVERADO
  • 5.2L
  • V8
  • 4WD
  • 14,200,000 MILES
Lost reverse but still has first. Do I need to replace the transmission?
Thursday, May 6th, 2021 AT 12:15 PM (Merged)
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
The transmission will definitely need to be removed and be rebuilt. Having the transmission rebuilt will be a lot less then having a new one installed. Most transmission shops have plenty of your transmissions ready to go (4L60E or the 4L80E) So it can usually be done in an 8 hour day. Hope this helps and thanks for using 2CarPros.
Danny-
MYDLITE58
  • 8 POSTS
Thank you and I totally appreciate you answering my question so quickly.
DANNY L
  • 5,648 POSTS
You're welcome!
Thanks again for using 2CarPros. Please feel free to use us again in the future.
Danny-
BUFORDBOX
  • 2000 CHEVROLET SILVERADO
  • V8
  • 200,000 MILES
Just happened today, cranked truck, put from P into R to back out, briefly engaged and moved about a foot in reverse before I hear a pretty loud noise from underneath. Something either broke. Or disconnected. Tran immediately disengaged. I have no reverse. When I select it I hear a high-pitched whine. Still have full function P and all forward gears.
Will still only crank in P or N. Fluid ok.
Internal?. Or any chance something less major?
Thanks a lot.
Thursday, May 6th, 2021 AT 12:16 PM (Merged)
BRIAN 1
  • 1,030 POSTS
The reverse reaction sun shell is stripped, this is a pretty common problem. They have an updated sun shell for these. You have to remove the trans and tear it down, there not to bad to do, I've done a few. Post back with any other questions.
