1994 Chevy Silverado
1994 CHEVROLET SILVERADO
TABERSKIT
mileage: 202000
Transmission: automatic with overdrive.
engine size: 305 V8
I have been experiencing some odd things lately with the tranny. I drive on the thruway / freeway alot, and @ approx. 65 miles mph, the speedo needle starts to ping from 65 mph to 80 mph and back again.
It seems to just go crazy. During this action, the truck feels like it is going to "Die", and then picks back up to speed and continues. Sometimes this happens once to three times per day. Any answers !
Aug 27, 2007 at 3:02 PM
SERVICE WRITER
  • CAR REPAIR CONTRIBUTOR
  • 9,123 POSTS
There should be a plug on the transmission drain pan.
Remove it, drain the fluid, replace the plug gasket, install the plug. Through the dipstick hole add a quart and check the fluid, add more as needed until level is good. Should be less than 3 quarts needed. You should use honda fluid.
Jun 8, 2007 at 8:15 PM
MERLIN2021
  • 17,250 POSTS
May be the VSS Vehicle speed sensor on most c1500 tranny's it's on the left side of the tranny. it has a 2 wire connector.
LTGREEN/BLK
Purp/WHT
there is also a vss buffer in the right side of the dash!
Aug 27, 2007 at 3:31 PM
