1993 Chevy Silverado Heat Gauge
CRIMSONDEVIL
  • 1993 CHEVROLET SILVERADO
  • V8
  • 212,500 MILES
My heat gauge stopped registerring comletely.
Wednesday, January 21st, 2009 AT 5:59 PM
  • 110,194 POSTS
Try replacing the temp sending unit. It's a cheap part, located near the t-stat housing and will most likely take care of the problem.
Let me know if this helps.
Thursday, January 22nd, 2009 AT 9:04 PM
BSPINKS
Joe is correct. There is a coolant sensor next to the t-stat housing but the main temperature monitor of the coolant is the temperature switch. You can find it under hood, on the driver side, just below the valve cover, between the front and center exhaust ports, mounted in the cylinder head. If the wires to the switch are broken or disconnected, your dash heat gauge will not work
Sunday, January 25th, 2009 AT 9:20 PM
Related General Content
