1990 Chevy Silverado Engine stalls and has low power
JIMC03561
  • 1990 CHEVROLET SILVERADO
  • V8
  • 107,000 MILES
My 1990 Pick up has been to several shops and the cost is getting high. I have been told it is a fuel pump problem, its will start and idle rough, but initial start up you have to continue to hit accelerator to keep it running. When I remove air filter and check I can see fuel spraying into the TBI. Is there a service kit for the TBI, I have also heard about a fuel pressure regulator diaphram kit that can be replaced. It seems to be over fueling? Or could it just be as simple as a fuel pump. The pump is still original.
Tuesday, May 20th, 2008 AT 7:42 AM
RHALL77
  • 3,361 POSTS
Is it setting a check engine light? Have you checked for vccum leaks?
Tuesday, May 20th, 2008 AT 8:06 AM
JIMC03561
No check engine light does not come on. But you can see and smell the fuel.
Tuesday, May 20th, 2008 AT 8:09 AM
RHALL77
  • 3,361 POSTS
Did you check the distrubitior cap and rotor to see there condition?
Tuesday, May 20th, 2008 AT 8:16 AM
JIMC03561
Yes. Dist cap and rotor are new. It has been on a computer and no codes or anything are present. The dealer wanted to replace fuel pump next at 1200.00 and I can do that for alot less.
Tuesday, May 20th, 2008 AT 8:19 AM
RHALL77
  • 3,361 POSTS
Why do they wanna replace it, is it low on pressure, what is the pressure do you know?
Tuesday, May 20th, 2008 AT 8:21 AM
JIMC03561
That was just the next step they say.
Tuesday, May 20th, 2008 AT 8:27 AM
RHALL77
  • 3,361 POSTS
Is it low on pressure or volume?
Tuesday, May 20th, 2008 AT 8:32 AM
