My s10 is high idiling and I cant find an adjustment screw how it anywere does it have one?
Friday, January 25th, 2008 AT 12:49 PM
LEGITIMATE007
MECHANIC
Does it have a carb? If not then there is a screw but it is factory set and should not be touched. If you have a high idol on a fuel injected vehicle then you should probably be looking firstly, for a vacuum leak. That usually causes the the high idol.
