EVAP vent solenoid location
ANONYMOUS
  • 2004 CHEVROLET MONTE CARLO
  • 72,000 MILES
Where is the evap vent solenoid located on a 2004 chevy monte carlo ss? Looking for picture or diagram.
Sunday, November 11th, 2012 AT 11:11 PM
-Evaporative Emission (EVAP) Canister Vent Solenoid Connector Behind left rear splash shield, in wheelwell.
Sunday, November 11th, 2012 AT 11:23 PM
2CP-ARCHIVES
  • 4,542 POSTS
  • 71,288 MILES
Need to know how to get to the r&r evap vent solenoid for a 2004 Chevy Monte Carlo SS
Thursday, December 5th, 2019 AT 12:27 PM (Merged)
  • 52,797 POSTS
REMOVAL PROCEDURE
Raise and support the vehicle. Refer to Vehicle Lifting.
Disconnect the evaporative emission (EVAP) vent valve electrical connector (1).
Remove the EVAP vent valve bracket bolt.
Remove the vent hose (4) from the EVAP vent valve.
Remove the EVAP vent valve from the bracket (2).
INSTALLATION PROCEDURE
Install the EVAP vent valve to the bracket (2).
Install the vent hose (4) to the EVAP vent valve.
Install the EVAP vent valve and the bracket.
NOTE: Refer to Fastener Notice in Service Precautions.
Install the EVAP vent valve bracket bolt.
Tighten
Tighten the bolt to 10 N.M (89 lb in).
Connect the EVAP vent valve electrical connector (1).
Lower the vehicle.
JIMMIE31421
  • 2003 CHEVROLET MONTE CARLO
  • 6 CYL
  • FWD
Where is the Canister Purge Valve Solenoid located on a 2003 Monte Carlo SS?
FACTORYJACK
  • 4,159 POSTS
Emissions (EVAP) Canister Purge Solenoid (3.8L VIN K) is on top front of engine, near center of upper intake plenum. Here is a picture.
SCARMECH
How can I check it for proper operation?
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,904 POSTS
Hey, SCARMECH
Remove the valve and then use two wires with a pigtail clips onto a battery 12 volt source. Next, touch the wires to the terminals inside the solenoid, you should hear a click which tells you it is working.
TERRANCE MAJORS
  • 2000 CHEVROLET MONTE CARLO
2000 Chevy Monte Carlo 6 cyl Front Wheel Drive Automatic
where is it located/emission control sensor
HMAC300
  • 48,601 POSTS
It's a valve not a sensor. It's by the gas tank and cannister purge. It 's got a red connection and red valve so it's easy to see. BUt if you left your gas tank loose after getting fuel it sets the same code
the gas cap has to click 3 times to fully seat.
