coolant temperature sensor location (?)...I have a v-6 3800
Dec 9, 2010 at 1:36 AM
Repair Safety Notice:
This information is for general instructional purposes only. Vehicle repair can be dangerous.
Verify all information, follow manufacturer service procedures, use proper tools and safety equipment,
and consult a qualified repair shop when needed.
CAR REPAIR CONTRIBUTOR
Coolant Temperature Sensor / Switch HVAC First Image. Coolant Temperature Sensor/Switch (For Computer) Second Image. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed. There are two different engines I gave both locations.
Images (Click to enlarge)
Dec 11, 2010 at 8:20 AM
FORDTURBO
MEMBER
1 POST
need to find ENGINE COOLANT TEMP. SENSOR on 3.4L dohc?
Nov 26, 2020 at 3:26 PM
(Merged)
BLUELIGHTNIN6
ECT sensor for the 3.4L engine is located near the coolant outlet
(Merged)
GETMUDDY69
MEMBER
i need the location of the coolant temp sensor i cant find it and the book i have dont tell me where its at can you help
(Merged)
BLUELIGHTNIN6
Hello
Thanks for the donation.
Your coolant temperature sensor is located under hood, driver side, upper engine area, rear of water outlet, mounted in intake manifold.
