2004 Chevy Malibu I need help to find my oil filter?
ELIZABETH29506
  • 2004 CHEVROLET MALIBU
Engine Mechanical problem
2004 Chevy Malibu 6 cyl Automatic 77000 miles
I need help to find my oil filter. When my husband was changing the oil in my car, both he and his father could not find the oil filter. Can you tell me where it is located?
Do you
have the same problem?
Tuesday, March 10th, 2009 AT 7:48 PM
BLUELIGHTNIN6
  • EXPERT
Should be located under a cap on the drivers side of the engine, behind the exhaust manifold. Use a 32 mm (1 1/4 in) socket on the hex on the top of the oil filter cap, or an oil filter wrench on the outside diameter of the oil filter cap to remove. Do NOT use pliers or a wrench as damage will result.
Thanks for using 2CarPros. Com!
Tuesday, March 10th, 2009 AT 8:05 PM
ELIZABETH29506
Thank you so much. I really did appreciate it very much.
Wednesday, March 11th, 2009 AT 7:48 PM
Recommended Guides
