HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Chevrolet
Lumina
Engine
Symptoms
Misfire
1990 Chevy Lumina MISFIRE
BRADLEY63
MEMBER
1990 CHEVROLET LUMINA
6 CYL
FWD
AUTOMATIC
20,000 MILES
90 LUMINA MISFIRE CHANGE WIRES & PLUGS 1 COREPACK STILL MISFIRE WHAT COULD BE THE PROBLEM
Monday, January 28th, 2008 AT 9:39 AM
MERLIN2021
MECHANIC
If you can narrow it down to the cylinder, check the coil tower for corrosion. Compression test may also be needed, could be a burnt or stuck valve.
Monday, January 28th, 2008 AT 9:41 AM
Please
login
or
register
to post a reply.
Related Engine Misfire Content
1990 Chevy Lumina Egr Code Engine Miss
Engine Runs Fine Until Warm With No Miss. After Engine Is Warm, Engine Misses At Idle. Drops Number Three Cylinder. Plug Wire Good...
Asked by
bobpick1962
1 ANSWER
1990
CHEVROLET LUMINA
VIDEO
Intermittent Misfire
Instructional repair video
GUIDE
Misfire Random Code P0300
The world of automotive diagnostics can be complex, with numerous codes and potential issues to keep track of. One of the more common engine diagnostic codes is P0300, which...
1990 Chevy Lumina Unexplained Engine Miss
For No Reason, It Will Randomly "miss" At Speed. I Could Be Driving The 30 Miles To Work At 65 Or 70, And 10, Sometimes 15 Miles, Maybe...
Asked by
Chas61
1990
CHEVROLET LUMINA
1990 Chevy Lumina Engine Misses
The Car Has A Steady Miss After Replacing Plugs, Plug Wires, Ignition Module, All Three Coils, Checked Fuel Injectors, Changed Fuel...
Asked by
wayneang
1 ANSWER
4 IMAGES
1990
CHEVROLET LUMINA
1990 Chevy Lumina Misfire
Engine Performance Problem 1990 Chevy Lumina 6 Cyl Front Wheel Drive Automatic Hello, I Have A 1990 Lumina Euro(3.1mpfi) With 86,000...
Asked by
90eurolumina
1 ANSWER
1990
CHEVROLET LUMINA
Can A Clogged Catalytic Convertor Make An Engine Misfire? Started Misfiring After Driving 5-6 Miles But Now It Starts Right Up And Misfires...
Asked by
ezalamo711
1 ANSWER
1990
CHEVROLET LUMINA
VIEW MORE
How to Repair an Engine Cylinder Misfire
