Where is located the ECM on a chevrolet impala 2000 3.4
Sunday, January 2nd, 2011 AT 3:35 AM
MECHANIC
The PCM in on the RH side of the engine compartment, forward of the strut tower, inside air box. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Image (Click to make bigger)
SPONSORED LINKS
Wednesday, February 9th, 2011 AT 2:45 AM
MIETECHROADRUNNERCOM
MEMBER
2002 CHEVROLET IMPALA
140,000 MILES
I need to check the ground wire on my pcm.
Wednesday, December 7th, 2016 AT 5:30 PM
(Merged)
SATURNTECH9
MECHANIC
It should be near air box under the hood.
(Merged)
KHLOW2008
MECHANIC
In air cleaner box
(Merged)
MEMBER
Thanks for that answer. My 2002 impala is a former police cruiser.I don't know if there would be any difference where the PCM would be located.I will check my air box and see. Thanks again!
SPONSORED LINKS
(Merged)
PAUL IMPALA
MEMBER
1 POST
Electrical problem
2002 Chevy Impala 6 cyl Two Wheel Drive Automatic
Where is the ECM located on a 2002 Chevy Impala?
(I have told behind the glove box)
(Merged)
BLUELIGHTNIN6
MECHANIC
Should be behind the left side of the dash, above the parking brake lever.
