Inner tie ride torque specs and replacement?
TRACI VINEYARD LESHER
  • 2007 CHEVROLET COBALT
  • 2.2L
  • 220,000 MILES
I need the torque specifications for an inner tie rod for my car. Can someone please help?
Thursday, September 7th, 2017 AT 10:44 AM
CARADIODOC
  • 33,752 POSTS
Here is the tie rod end torque secs plus a guide to help walk you through the job with instruction in the diagrams below to show you how on your car.
Install a new outer tie rod nut.
Tighten the nut to 25 N.m (18 lb ft) plus 90 degrees.
https://www.2carpros.com/articles/tie-rod-end-replacement
Thursday, September 7th, 2017 AT 5:07 PM
LINDA B4
Suspension problem
2007 Chevy Cobalt 4 cyl 23000 miles
We seem to be have a problem with noise in the front end. My husband thinks maybe a tie rod or ball joint on the drivers side. Have you heard of anyone else having such a problen
Monday, October 12th, 2020 AT 7:05 PM (Merged)
STEVEC672007
I have a 2007 Cobalt also and I went through the same problem with my car. The noise started on one side then the other side started making it too. It is the control arm bushings. They get moved out of position from hitting potholes and bumps in the road. I had them replaced now my car is as good as new.
