Leaking water on passenger side?
JRCPRO
  • 2010 CHEVROLET COBALT
  • 2.0L
  • 4 CYL
  • FWD
  • 80,000 MILES
I have a water leak on the passenger side when I run the A/C, I need to know where the drain is, I cannot locate any hoses, I did find a plastic drain type thing coming out of the firewall on the passenger side where I think the evaporator is located, any help will go a long way, really don't want to send it to a shop and pay out the rear for a simple fix. Thanks
Sunday, June 21st, 2015 AT 1:38 PM
RACEFAN966
  • 5,029 POSTS
There is a TBS on this here it is with instructions on how to fix it below.
TECHNICAL
Bulletin No: 09-01-37-002E
Date: November 01, 2011
Subject: Water Leak into Front and Rear Passenger Floor and/or Carpet Wet (Inspect White Plug in HVAC Evaporator Drain and Apply Sealer to Front of Dash Area)
Models:
2008-2010 Chevrolet Cobalt
2008-2011 Chevrolet HHR
2008-2012 Chevrolet Malibu
2008-2009 Pontiac G6
2008-2010 Pontiac G5
2008-2009 Saturn AURA
Supercede:
This bulletin is being revised to add the 2012 model year. Please discard Corporate Bulletin Number 09-01-37-002D (Section 01 - HVAC).
Condition
Some customers may comment that the front and rear floor carpet is wet on the passenger side.
Cause
This condition may be caused by a plugged HVAC evaporator Drain. In some cases, water from the HVAC system will drain back though the front of the dash.
Correction
Note
Reposition of the heat shield is not necessary on a Cobalt and HHR.
1. Verify the customer's concern. If there is water on the passenger side front floor area, raise and suitably support the vehicle. Refer to Lifting and Jacking the Vehicle in SI.
2. Inspect the operation of the drain.
Note
Make sure that small debris is not plugging up the drain.
Tuesday, June 23rd, 2015 AT 7:23 AM
JRCPRO
Thanks, this fixed it, I love this site, how can it be free?
Tuesday, June 23rd, 2015 AT 2:19 PM
MOORESD
  • 2009 CHEVROLET COBALT
  • 100,000 MILES
When I turn on the air conditioner there is water leaking inside the car. The water is leaking from under the glove compartment. Can someone help me please?
Tuesday, July 28th, 2020 AT 2:25 PM (Merged)
  • 108,310 POSTS
There is a drain that runs from under the dash to under the hood on the firewall. It must be plugged. It will be a rubber hose about 3/4" in diameter. Check where it is closest to the road for being plugged with dirt.
This video will help
https://youtu.be/q9_MZiS2_NE
SSCHAROLD
  • 2006 CHEVROLET COBALT
  • 4 CYL
  • FWD
  • 79,000 MILES
Air conditioning started leaking clear water into the floor board. Comming form the ac blower, what is the cause of this and is it an easy fix. Some thing I can do myself or do I need take it to a shop.
Tuesday, July 28th, 2020 AT 2:32 PM (Merged)
SATURNTECH9
  • 30,869 POSTS
Ur a/c drain is clogged and ur hvac box is full of water. Easy fix go under the hood and look at the fire wall u will see the drain its just a hole get a metal coat hanger make something out of it to get and there and clean the drain then stand back and let the flood come. Hope this helps.
Louie
HABADO
  • 2005 CHEVROLET COBALT
2005 Chevy Cobalt
water is leaking on the passenger side floor from under the glove box area, maybe from the air cond.
DOCFIXIT
  • 18,828 POSTS
Hi
The condensate drain is blocked. Look out in engine compartment along passenger side bulkhead small tube protruding. Take a wire clean it out.
Hope this helps
Thanks for donate
KDUHON_07
  • 4 CYL
  • FWD
  • 77,000 MILES
My car is leaking alot water into my passenger seat floor board. The coolant has NOT been running hot, the antifreeze and water are at the same level as it was when I checked it I went and had the air conditioning thing that leaks water onto the ground blown out incase that it was stopped up or something but that didnt fix it. Please help dont know what it could be.
Hi kduhon_07, Welcome to 2carpros
If its not coolant and from the rain thru the windshield its time to open it up and investigate-the AC drainage is still clogged-up and backing it up
JERRYY
  • 135,547 MILES
My air conditioner keeps leaking on the passenger side floorboard what can I do to fix this problem. There water leaking everytime I turn the AC off or on the water leaks down the passenger side is this an occurrence problem with these type of model cardsif so can you give can you provide me with a solution of of how I can fix the problem and the steps I need to take oh where do I have to look 4 thank you very much for your time in this matter
DOCFIXIT
  • 18,828 POSTS
Locate drain tube on bulkhead below where heater hoses and AC lines attach. Use small wire to probe and cleanout. Here is a video to help with diagrams below.
CSPINK
  • 4 CYL
  • FWD
  • 70,000 MILES
When I run the ac in my car I get a big puddle of water on the passenger side floor board. Everyone said the drain was plugged, service dept. Said it wasn't. What could it be and how do I fix it?
Tuesday, July 28th, 2020 AT 2:33 PM (Merged)
BRIAN 1
  • 1,030 POSTS
Follow this info, Some customers may comment on water leaking on the front passenger side floor of the vehicle. This leak would occur under high ambient temperatures and high humidity situations when the customer has the air conditioning on high. Leaks will appear to be coming from the HVAC module where the heater core cover and lower case come together. Also, some customers may comment on water droplets blowing out of the vents when the A/C is on high.
Cause
This condition may be due to water condensing in the HVAC case that adheres to the upper surface in the tongue and groove area of the lower case and then leaking out.
Correction
Install the foam gasket between the heater core cover and the lower HVAC case at the location of the leak. Post back with any other questions
RODBETO
Hi, I’ve been having water leak into bottom of glove box and to the passenger floor on my 10 Chevy Cobalt LS. I’ve located drain and flushed it with nitrogen and all the water comes out. It stopped leaking water, but a week later the issue came back, and water continues to seep through the same way. Why does water continue to come out? And what do you recommend?
Sunday, August 28th, 2022 AT 8:26 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,057 POSTS
So, a piece of the insulation must be getting in the way of the drain which will cause it to plug up again. Can you get a small pair of tweezers in the drain to help pull out any partials? Use a flashlight to see up into the drain to confirm.
This video may help:
Monday, August 29th, 2022 AT 12:48 PM
MGE8
Alternative cause of water on floor in a 2005 Chevrolet Cobalt water on the passenger side carpet cause can be to check the area under the windshield washers under the large plastic cover that runs the entire dash on the outside that rain water falls on there is a large hole in the body frame of the car up under there on the passenger side there that has a rubber diaphragm that gets old and leaks or falls into the large metal hole there and or leaks water, it is a straight drop into your cabin air filter for water if the plastic rubber diaphragm is old and water will go right in the glove box on the air filter and so when it rains the carpet gets wet. To inspect you need to remove the windshield washers with a special tool on amazon to make things easy, linked here,
[FIRSTINFO Light Windshield Wiper Arm Puller/Removal Tool (Fit Opening dimension: 0.59 Inch (15.2mm) Internal Height: Approx. 1.06" (27.2mm)][Model Number: F3391]
use this tool to remove the wipers easily, just spin the thing a few times and the wiper pops off then step two lift up the plastic cover there is a plastic retainer type of plunger plug insert on the outside of each side of the plastic cover looking down at the plastic cover, lift those out first then lift off the cover. The washer fluid line is attached so you need to rest it on the engine not totally off the vehicle unless you disconnect the washer fluid line. You'll see it when you start to lift the plastic cover how it runs and where is connects.
Now that the cover is off and set aside on the left side, the passenger side up close to the windshield there is a large rectangular hole and or plastic cover about as wide as a paper towel. If your plastic rubber cover is old and leaking replace it and or you may find it stuffed inside the hole from falling into the hole being old. The replacement is called a "deflector" [part number: 15296710] GM, GMC, Chevrolet, Pontiac parts dealers have it. It's a common issue on these vehicles with age leaking water. There is an automotive glue 'goo' silicone adhesive high heat application required of some kind that needs to be used to secure your new deflector to the body. It is a hole that is tilted some with the body of the car and not flat so you can't use any flat random piece of anything to re-cover the hole but auto parts stores do carry a diaphragm sheet in a roll of a rubber plastic as I saw in one video fix for this. You can maybe use high heat RTV silicone which is pretty common. Not sure what the manufacturer goo is called. Whatever it is this will stop water leaking if it is the cause. Basically like having the sunroof open if that deflector isn't there.
See this blog post for pictures and a more detailed how to.
[https://chevycobaltblog.blogspot.com/2022/11/wiper-remover-2005-chevy-cobalt.html]
Saturday, November 12th, 2022 AT 5:22 PM
KEN L
  • 43,057 POSTS
Excellent addition to this thread! Please feel free to use 2CarPros anytime!
Monday, November 14th, 2022 AT 9:58 AM
