1995 Chevy Camaro code Reader
OMAR198569
  • 1995 CHEVROLET CAMARO
  • V8
  • MANUAL
  • 100,000 MILES
I have a 1995 Camaro which is an OBD 1.5. I Can't seem to find a code reader that will work with my car. I would rather buy a code reader than take it to a shop. So my question is where can I find a code reader that will work with my car.
Do you
have the same problem?
Saturday, June 21st, 2008 AT 4:05 PM
Jumper A to B on the ALCL and count the flashes example DTC 12 Flash pause then flash flash it will show two more times before it goes to the next code if any
http://www.2carpros.com/forum/automotive_pictures/12900_GM_ALCL_4.jpg
Saturday, June 21st, 2008 AT 4:13 PM
Chevrolet
13 Open Oxygen Sensor Circuit
14 Coolant Temperature Sensor (High Temp Indicated)
15 Coolant Temperature Sensor (Low Temp Indicated)
21 Throttle Position Sensor (Signal Voltage High)
22 Throttle Position Sensor (Signal Voltage Low)
23 Manifold Air Temperature (MAT) Low Temp Indicated
24 Vehicle Speed Sensor (VSS) Circuit
25 Manifold Air Temperature (MAT) High Temp Indicated
32 Exhaust Gas Recirculation (EGR) Circuit
33 Manifold Absolute Pressure Sensor Circuit (High Sig.)
34 Manifold Absolute Pressure Sensor Circuit (Low Sig.)
35 Idle Air Control (IAC)
41 Cylinder Select Error
42 Ignition Control (IC) Circuit
43 Knock Sensor (KS) Circuit
44 Oxygen Sensor Circuit (Lean Exhaust Indicated)
45 Oxygen Sensor Circuit (Rich Exhaust Indicated)
51 EEPROM or ECM Failure
53 System Voltage Overcharge
54 Fuel Pump Circuit (Low Voltage)
55 ECM Error
61 Degraded Oxygen Sensor
62 Transaxle Gear Switch Signal Circuit
63 A/C Refrigerant Pressure Sensor Circuit
Saturday, June 21st, 2008 AT 4:20 PM
Recommended Guides
