The van is backfiring I was wondering if I have a crossed plug wire. I replaced the plugs and wires also. Thanks For the help
Friday, June 20th, 2008 AT 9:14 PM
KEN L
MASTER CERTIFIED MECHANIC
Yes, this can be the problem, here I have included some firing order diagrams so you can double check.
Please let me know if you need anything else.
Best, Ken
SPONSORED LINKS
Tuesday, January 17th, 2017 AT 12:46 PM
JSNAPZ1212
MEMBER
1 POST
1995 CHEVROLET ASTRO
What is the Firing order for 1995 chevy astro 4.3L
Monday, June 29th, 2020 AT 11:33 AM
(Merged)
SERVICE WRITER
MECHANIC
1-6-5-4-3-2
(Merged)
LEILANI67
MEMBER
1993 CHEVROLET ASTRO
160,000 MILES
DONT HAVE THE TROUBLESHOOTING SECTION IN MY MANUAL. COULD I PLEASE HAVE THE FIRING ORDER OF SPARK PLUGS FOR CHEVY ASTRO. THANK YOU!
(Merged)
JDL
MECHANIC
What is the litre size of engine?
SPONSORED LINKS
(Merged)
JDL
MECHANIC
This info is for the 4.3L engine.
Image (Click to make bigger)
(Merged)
WESLEY_MYS
MEMBER
6 CYL
2WD
AUTOMATIC
174,000 MILES
My distributor is 380 out. Best way to reset it
(Merged)
MECHANIC
Do you have a repair manual if so-Put the engine no.1 piston on its compression stroke/TDC, align the cam and crank sprockets to their markings, put crank pulley on TDC/0 deg and rotor pointing to no.1 cap tower.
(Merged)
GENTECHIT
MEMBER
6 CYL
AWD
AUTOMATIC
256,000 MILES
When the plug wires are coming from the distributor cap to the Spark Plugs, Which wire goes to which plug?
(Merged)
MECHANIC
Here is a picture of what you need.
Let me know if it helps.
(Merged)
ANDYS
MEMBER
1992 CHEVROLET ASTRO
6 CYL
2WD
AUTOMATIC
The order on a distrubeter cap. 1992 astro cahevy 2 w/d
(Merged)
DOCFIXIT
MECHANIC
This help
SPONSORED LINKS
(Merged)
ANDYS
MEMBER
The cap does not have any numbers so I dont know which is one
(Merged)
ANDYS
MEMBER
It turns on but I feel like I have to put more force on the gas. It feels more heavy to ride
(Merged)
DOCFIXIT
MECHANIC
How many miles on plugs, filters wires cap ect. Has fuel pressure been checked. Check engine light on? This sudden or came on over time?
(Merged)
ERNIE SWAN
MEMBER
1 POST
1990 CHEVROLET ASTRO
6 CYL
2WD
AUTOMATIC
47,350 MILES
I was hoping to find out the wiring order of the spark plug wires at the Distributor cap?
