Camshaft position sensor
BROKENEGGS
  • 2004 HONDA ODYSSEY
  • 3.5L
  • 6 CYL
  • 200,000 MILES
This problem was repaired check engine light went out after repair, but after a few minutes it came back on. Had it rechecked and the results said the camshaft position needs to be replaced again. When I took it to be inspected The report said MIL status he Malfunction Lamp Is Commanded On.
Do you
have the same problem?
Thursday, June 13th, 2019 AT 4:02 PM
  • EXPERT
Good afternoon,
The repair was unsuccessful. Whatever they did was not the correct repair.
Codes rarely identify bad parts, just failed systems. Diagnostics have to be done to determine the failure.
What was the exact code that was set?
Thursday, June 13th, 2019 AT 4:09 PM
BROKENEGGS
I don't know about codes. I had this repair made by a come to your home mechanic. What he did or what codes he used I have no idea. What does this inspection report mean by The Malfunction indicator lamp is commanded On?
Thursday, June 13th, 2019 AT 4:30 PM
  • EXPERT
That means a code is stored in the module. I need that code to help you.
You can go to a parts store and have them read it for free. Once I know that code, I can get the information on what needs to be checked.
Thursday, June 13th, 2019 AT 4:32 PM
BROKENEGGS
I have the readout from AutoZone I see it says code po365 indicates a fault in the bank 1 camshaft position sensor b electrical circuit for a predetermined period of time.
Thursday, June 13th, 2019 AT 4:41 PM
  • EXPERT
Okay, Let me check. That code indicates a wiring issue.
Possibilities
P0365
Descriptor
Probable Causes
Camshaft Position (CMP) Sensor B
Camshaft Position (CMP) Sensor B Sensor Wires Shorted
Camshaft Position (CMP) Sensor B Wires Open
Poor Connections or Loose Terminals At Camshaft Position (CMP) Sensor B and At Powertrain Control Module (PCM)
Flow chart that needs to be followed
DTC P0365: CMP Sensor B No Signal
1. Reset the PCM.
2. Start the engine.
Is DTC P0340, P0341, P0365, P0366 indicated?
YES - Go to step 3.
NO - Intermittent failure, system is OK at this time. Check for poor connections or loose terminals at the CMP sensor A/B and at the PCM.
3. Turn the ignition switch OFF.
4. Disconnect the CMP sensor A/B 4P connector.
ImageOpen In New TabZoom/Print
5. Measure resistance between the terminals of the indicated sensor (see table).
Is there 1,850 - 2,450 Ohms?
YES - Go to step 6.
NO - Replace the CMP sensor A/B.
6. Check for continuity to body ground on both terminals of the indicated sensor individually.
Is there continuity?
YES - Replace the CMP sensor A/B.
NO - Go to step 7.
7. Reconnect the CMP sensor A/B 4P connector.
8. Disconnect PCM connector C (31P).
9. Measure resistance between the terminals of the indicated sensor on the PCM connector (see table).
YES - Go to step 10.
NO - Repair open in the indicated sensor wires (see table).
10. Check for continuity between body ground and PCM connector terminals C20 and/or C29 individually.
YES - Repair short in the indicated sensor wires.
NO - Substitute a known-good PCM and recheck. If the symptom/indication goes away, replace the original PCM.
Thursday, June 13th, 2019 AT 4:49 PM
BROKENEGGS
This is Greek to me so I will have a pro to check this out.
Thursday, June 13th, 2019 AT 5:00 PM
  • EXPERT
Yes, not a tech that comes to your home. A real shop who will do a real diagnostic.
Thursday, June 13th, 2019 AT 5:07 PM
BROKENEGGS
Thanks.
Friday, June 14th, 2019 AT 6:09 AM
  • EXPERT
You are welcome.
Always glad to help.
Friday, June 14th, 2019 AT 6:11 AM
BROKENEGGS
But it is a shame because this guy has his own real shop also.
Friday, June 14th, 2019 AT 6:12 AM
  • EXPERT
I understand but he just took a guess without doing proper diagnostics. I hope he does not do that at his shop as well.
Friday, June 14th, 2019 AT 6:16 AM
BROKENEGGS
But I am wondering what kind of mechanic he is. I don't think he knows how to set codes. Because I drove it down the street and it just shut off just like if you had switched it off and would not crank until I removed the key from the switch and reinserted it.
Friday, June 14th, 2019 AT 6:18 AM
  • EXPERT
Set codes?
Friday, June 14th, 2019 AT 6:21 AM
Recommended Guides
