Power window
RICK MARTIN
  • 2004 BUICK LESABRE
  • 6 CYL
  • 89,000 MILES
Buick 2004 LeSabre power windows all work but the passenger side can't open the window from the main driver switch or the passenger switch what could be the problem?
Monday, November 29th, 2010 AT 8:42 PM
WRENCHTECH
  • 20,757 POSTS
That's probably a bad main switch but it should be tested before replacing.
this guide can help you find out whats wrong
https://www.2carpros.com/articles/electric-window-repair
Monday, November 29th, 2010 AT 8:53 PM
JDL
  • 16,098 POSTS
Check for applicable trouble codes. There are power window trouble codes. There are modules in each door.
Monday, November 29th, 2010 AT 8:54 PM
WRENCHTECH
  • 20,757 POSTS
I just reread your question and realized you said it was both switches. That means you need to test the motor.
SATURNTECH9
  • 30,870 POSTS
Most likely it's a bad window motor you would have to remove the inner door panel and make sure you were getting power and ground to the motor. If you were then you would have to make sure the glass wasn't binding. Also sometimes if you lightly tap on the motor while moving the switch it get's the motor moving for a short period of time if the motor is bad.
Monday, November 29th, 2010 AT 8:55 PM
REDD06
  • 2002 BUICK LESABRE
Yes on my car the power locks, the pop trunk nor does my interior lights work what could be the problem its been going on for about two months and I cant seem to find the problem. And my windows only come down when my car is cranked it will not come on when I just turn my key either way with out my car being on.
Tuesday, January 7th, 2020 AT 12:27 PM (Merged)
BMRFIXIT
  • 19,053 POSTS
Check fuses and relay
check fuses in the rear fuse box located under left rear seat
https://www.2carpros.com/forum/automotive_pictures/99387_Graphic2_71.jpg
https://www.2carpros.com/forum/automotive_pictures/99387_Graphic1_137.jpg
TYLER ERB
I had the problem of only drivers window rolling down. No dome light when passenger doors opened. Wiring under the drivers seat ( not hard to take out ) got wet then corroded. I could see it right away when I pulled my carpet up.
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,904 POSTS
Excellent addition to this thread! Please feel free to use 2CarPros anytime!
DARKIN99
  • 7 POSTS
6 cyl Front Wheel Drive Automatic 55000 miles
Every few months the driver's side window won't go down. No noise - completely dead. The window won't work no matter how many times I press the button. But the next morning the window will work the first time I press the botton and will work consistantly for a couple of months until it happens again. Each time it fixes itself the next day. I tried jiggling the button, pounding the door panel and slamming the door thinking it might be a loose wire but nothing fixes it until the next day when it works like nothing happened. What's wrong with it?
Monday, January 13th, 2020 AT 12:42 PM (Merged)
KEN L
  • 42,904 POSTS
There is a door and window control module that goes bad in these cars making the window not work from time to time. Here are some guides to help you see what I am talking about. You will need to remove the door panel to access the module.
https://www.2carpros.com/articles/door-panel-removal
and
Cheers, Ken
KCORBO
  • 2001 BUICK LESABRE
  • 6 CYL
  • FWD
  • 98,000 MILES
Car is totally dead. Took back door apart to fix the window that does not go up. Finally received the part went out to the car totally dead. Remotes do not work, also the key will not even open the trunk. The AAA said when they came to jump it and got nothing that a kill switch was probably tripped. We bought this car used about 4 yrs ago. Is it possible the window needs to be done and reconnected for the car to turn over? Or is there possibely a kill switch?
  • 108,200 POSTS
The window has nothing to do with it and I never heard of a kill switch. THere is an Auto Shut Down (ASD) for the engine, but that won't kill all of the electrical system.
Have you checked to make sure the battery terminals and grounds to the engine block are clean and tight? I realize that may sound elementry to you, but many times that causes the problem. Also, does the battery have a good charge producing 12+ volts?
LADYBUGPAINTER
  • 5 POSTS
  • V6
  • RWD
  • 100,020 MILES
The driver side door/window electric control does not work to operate any component throughout the car.
Monday, January 13th, 2020 AT 12:43 PM (Merged)
SATURNTECH9
  • 30,870 POSTS
What if open the door slowly while trying them?
LADYBUGPAINTER
  • 5 POSTS
Tried opening the door slowly while trying the buttons. No good.
SATURNTECH9
  • 30,870 POSTS
Do you have a test light to do some testing?
LADYBUGPAINTER
  • 5 POSTS
We tried opening the door slowly while trying the buttons and it did not help.
RADAR4077TH
  • BUICK LESABRE
Hello I'm Jack Whatchier a proud owner of a 99 Buick Lesabre Limited it has 97,602.7 miles and has a 3800 stage 2 v6 over the last 3 days my power windows sometimes work, it started out with just the passenger side door not going up from the master panel it then corrected itself then the rear windows started the same system this time none of the switches worked then it fixed itself and the same problem has occurred again I noticed sometimes when trying to get windows up that my lights go dim for an instant and sometimes the windows moves, it this a problem on the fuse relay center or what I'd rather start out with the cheaper fixes before I go to a dealer thank you for your help
MERLIN2021
  • 17,250 POSTS
Jack the fist thing I would look at is the wires were they come out of the door, and bend all the time.
If you untape them you will most likly find broken wires that will sometimes match up and sometimes not!
LADYBUGPAINTER
  • 5 POSTS
No we do not have a test light here.
