1991 Buick Century Dies out when in gear
KUTIBOY01
  • 1991 BUICK CENTURY
  • 6 CYL
  • FWD
  • 96,000 MILES
My Buick Century runs fine when it's at idle but when you put it in gear it wants to die out but will only stay running for a little bit if you keep holding the brake. I do not know what the problem is. If you have any suggestions, please let me know.
Thursday, January 7th, 2010 AT 8:31 PM
  • 110,194 POSTS
Has the check engine light come on? Have you checked fuel pump pressure, vacuul leaks?
Friday, January 22nd, 2010 AT 10:44 AM
KUTIBOY01
The check engine light did come on but went off. I replaced the computer and no codes were thrown after that. It would run fine after that but there was no acceleration while in gear. It said it was running too lean so I replaced the M.A.P. Sensor and now it says it runs too rich. I'm running out of options
Friday, January 22nd, 2010 AT 4:42 PM
  • 110,194 POSTS
Have you checked the general things like the catylatic converter, fuel pump pressure?
Friday, January 22nd, 2010 AT 9:17 PM
