1989 Buick Century
JJTRENARY
  • 1989 BUICK CENTURY
Engine Cooling problem
1989 Buick Century 6 cyl Two Wheel Drive Automatic
i had a bad thermostat but no water leakage i changed the thermostat it was definetly the problem put it all back together and now my top raidater hose has no preasure and when i squeeze it water sprays out of the bolt on the goose neck where i put the thermostat and i can hear it gurggle in the reserive tank did i break somthing or forget somying i took this pic a seceond ago the drip is small but its right were the goose neck bolts to the engine
http://www.2carpros.com/forum/automotive_pictures/566871_105_1.jpg
Sunday, August 29th, 2010 AT 12:40 PM
HMAC300
  • 48,601 POSTS
You may have put the thermostat in backwards and the not clened all the material off of both sides of the thermostat housing. Or the housing because it is aluminum may have eroded on the housing itself. Pull it back apart and inspect it carefully. You haven't mentioned anything about overheating so it may be ok, just an eroded housing. You might also have to put some teflon type sealer on the bolts so they don't leak as well.
Monday, August 30th, 2010 AT 1:24 PM
JJTRENARY
Im going to have a shop check it out I dont wanna break anything thanks for the info and quick response
Monday, August 30th, 2010 AT 3:02 PM
Related General Content
