Timing belt diagram
JOHN KINCH
  • 2001 HYUNDAI ACCENT
I need picture of timing belt marks
Tuesday, August 25th, 2009 AT 6:52 PM
BLUELIGHTNIN6
  • 16,542 POSTS
This guide shows you the camshaft timing marks toward the bottom of the page.
https://www.2carpros.com/diagrams/hyundai/accent/2001
Tuesday, August 25th, 2009 AT 11:04 PM
SAWDUSTANNIE
  • 4 CYL
  • 60,000 MILES
My daughter was told that Hyundais are notorious for breaking their timing belts earlier than the recommended replacement time. When is a good time to replace the belt. She has 60,000 miles on it now ; bought it used 6 months ago & is trying to keep it well maintained. Should she change it now or wait?
Thursday, July 18th, 2019 AT 1:28 PM (Merged)
KHLOW2008
  • 41,814 POSTS
Hi sawdustannie,
If the timing had not been replaced yet, now is the time to do it.
Waiting in this case is a dangerous game.
DLRUSSELL82
  • 4 CYL
  • MANUAL
  • 111,779 MILES
If my timing belt wasnt changed at 90,000kms and now is 20,000 overdue, how long have I got to get it fixed, is this a timebomb? I was quoted $1000 for the job, was my mechanic including labour costs as they said it is time consuming? Do you recommend getting another quote?
BLUELIGHTNIN6
  • 16,542 POSTS
With 20k over due, I would definitely try to have it replaced sooner rather than later. The $1,000 estimate is WAY over...it only take about 3 hours on this vehicle to replace the timing belt. An estimate is below of what it should cost you..
https://www.2carpros.com/forum/automotive_pictures/261618_Noname_1437.jpg
NISSAN440
  • 4 CYL
  • 91,000 MILES
If timing belt breaks on 1.6l does it damage valve or piston?
BLUELIGHTNIN6
  • 16,542 POSTS
All Hyundai engines, L4 and V-6 are interference engines so yes it is very possible to have valve and piston damage if timing belt breaks during operation.
CHUMASH915
  • 4 CYL
  • FWD
  • 85,000 MILES
Have every thing off but the lower cover and the pulley how do I get that pulley off?
  • 108,320 POSTS
If you are refering to the harmonic balancer, you need a puller for it. Most parts stores will rent what you need.
HAMZAMLT
  • 4 CYL
  • 32,000 MILES
My car engine msiing some time when I drive
Engine running rough or misfiring can be cause by the following-inspect and test all the following below:
1. Defective spark plug.
2. Inadequate spark/coil, defective spark plug wire.
3. Lack of compression
4. False air leakage.
5. Faulty fuel injectors.
6. Insufficient fuel pressure.
7. Contaminated fuel.
8. EGR valve that is leaking.
9. Oxygen sensors.
10. Throttle position sensor.
ICEMAN1748
  • 1999 HYUNDAI ACCENT
  • 4 CYL
  • MANUAL
  • 165,000 MILES
I would like to know how to line up the timing marks on the engine because my belt broke and now the timing needs to be lined up
BLUELIGHTNIN6
  • 16,542 POSTS
https://www.2carpros.com/forum/automotive_pictures/261618_Graphic_747.jpg
DANO101
  • 1997 HYUNDAI ACCENT
  • 4 CYL
  • FWD
  • MANUAL
  • 180,000 MILES
Instructions on re installing timing belt. I can not get the car to fire
Thursday, July 18th, 2019 AT 1:29 PM (Merged)
  • 31,937 POSTS
Hi there,
Did this belt break? Have you had the head off?
Mark (mhpautos)
DANO101
No the belt did not break and I have already changed it. I am having problems getting the timing right and getting the car to run. I have not had the heads off. I did have a frind check the compression and everything seems fine.
ANGIE
  • FWD
  • MANUAL
  • 150,000 MILES
Crank timing settings
HMAC300
  • 48,601 POSTS
Crank timing setting are done by computer if off just put it close to tdc on #1 then a pro has to use his scanner to put it in sync with crank sensor.
