I need to open the hood?
ANONYMOUS
  • 2011 FORD F-150
  • 3,300 MILES
I have 2011 F-150 XLT Supercab, bought new this year. Since purchase I have alot of annoying wind noise/whistling. I had the noise before putting on a hood deflector and have taken off and test drove without any improvement repeatingly. On F-150 forums I see that others have this problem too. Any ideas, resolutions, and FIXES would be appreciated. This is my only complaint with my truck
Sunday, December 9th, 2012 AT 12:43 AM
More then likely we have an air leak in the windshield but lets start with opening the hood and finding out if there is anything out of place or left open like the air box or anything else.
https://www.2carpros.com/articles/how-to-open-a-car-hood
Next we need to start using painters tape and tape off the windshield boarder and door gaps. Then drive the vehicle and see if the noise is gone.
If it is, then start removing strips of tape until the noise comes back. Then you know where the noise is coming from.
Here is another guide that will help with noise in more general:
https://www.2carpros.com/articles/engine-noises
This could also be an issue with the HVAC system or the PCV system.
When does the noise come and go? Does it get better at slower speeds, higher speeds?
If this is not affected by speed but when the engine is warm, I would replace the PCV and see if that takes care of it. I have seen this cause a whine noise when the engine heats up. Basically they get clogged and cause a noise like this.
I attached the process below on how to replace the PCV for all engines.
Let us know this info and we can go from there. Thanks
Tuesday, February 9th, 2021 AT 6:15 PM
VICKEY SILVINO
  • 2004 FORD F-150
  • 5.1L
  • V8
  • 100,000 MILES
Can I change the hood with another year or an expedition?
Wednesday, February 10th, 2021 AT 9:39 AM (Merged)
HMAC300
  • 48,601 POSTS
Check with a junk yard or body shop there may be different hoods for light duty as well as heavy duty.
STEVE W.
  • 12,973 POSTS
Hollander show the Expedition uses its own hood not interchangeable with other trucks. The 2003-2006 shows as usable years for a 2004.
K REEDER
  • 1997 FORD F-150
  • V8
  • 134,000 MILES
The HOOD DOES NOT STAY SHUT, the the pull inside the truck is loose, could it be the cable or is it the latch itself under the hood. Is the cable hard to replace if this is the problem?
BLUELIGHTNIN6
  • 16,542 POSTS
Seems like the cable has binded up somewhere which is keeping pressure on the hood latch. Try spraying some lubricant on the release cable any and everywhere you can access/see it. Then work it in and out with the release handle in cable.
MSDEBBIE1205
  • 1994 FORD F-150
  • V8
  • 4WD
  • MANUAL
  • 112 MILES
My hood latch is jammed and I cant get it to open or closeed all the way help
Wednesday, February 10th, 2021 AT 9:40 AM (Merged)
BMRFIXIT
  • 19,053 POSTS
Remove front grill and unbolt the latch
open hood and remove and replace latch
https://www.2carpros.com/forum/automotive_pictures/99387_Noname_3.jpg
LYNNDAVIS
  • 1986 FORD F-150
  • V8
  • 133,000 MILES
My 1986 Ford F150's hood release under the dash has no tention-I just opened it an hour ago but it acts differently now. How else can I open the hood? I'm trying to charge the battery? It isn't the hood latches turn to break!
CJ MEDEVAC
  • 11,004 POSTS
Can you get your pal to hold the release OUT, while you "Rattle" the hood?
The release or mechanism, in the hood, could be broken or out of adjustment.
I use any and all available resources when I'm in a bind!
If you could get it there, or get one of them to you.
A small Ma and Pop (maybe self serve) type auto salvage yard guy could probably pop it, and diagnose it too! Sounds dumb, but they do like to strut their stuff, when they express their expertise! Maybe give 'em a nice tip for the help!
The Medic
