Possible bad CV axles
JGONZO2398
  • 348 POSTS
And just as a reminder, in the past year, I have replaced front sway bar links, front lower control arms (with new bushings), all four shocks and struts (with springs pre-installed), rear stabilizer bars, inner and outer tie rods, and just last week had the ball joints and both inner and outer CV axles replaced. All new parts. I just checked for any play in the sway bar links or tie rods, they are as tight as can be, no movement at all.
Tuesday, June 8th, 2021 AT 1:52 PM
JGONZO2398
  • 348 POSTS
I know "new" does not really mean much as new parts can not fix the problems sometimes and be faulty as well, but this clunk sound started about a month ago. The most recent repair prior to the CV axles and ball joints was about six months ago, and that was the struts, control arms and the rear stabilizer links.
  • 52,797 POSTS
Check the upper strut mount on the strut. See if you can feel the noise there.
Also, check the link kit from the strut to the frame. Two common points of noise like this.
JGONZO2398
  • 348 POSTS
So I pushed the car back and forth with my hands, and the noise is coming directly from the upper portion of the strut. But the mounts look okay, they do not move when I shake the car, and the noise is clear from both the drivers and passengers side. Here is a video of the drivers:
JGONZO2398
  • 348 POSTS
These are brand new struts. Why would it be making that noise?
JGONZO2398
  • 348 POSTS
These are the front struts I bought. If that helps.
JGONZO2398
  • 348 POSTS
I went ahead and tried to tighten the nuts on the upper strut mount, but they are as tight as they can be.
  • 52,797 POSTS
Okay, then check the link that is bolted to the strut. That is the other part I was talking about.
JGONZO2398
  • 348 POSTS
The sway bar, yeah. It does not seem like it is coming from that. I tried moving that part with my hand, shaking it and pulling on it, it does not budge whatsoever.
  • 52,797 POSTS
Have someone bounce that side up and down and see where you can feel the noise.
It has to be pretty obvious.
JGONZO2398
  • 348 POSTS
Here is one more time from the drivers side.
  • 52,797 POSTS
Okay, still the same answer.
JGONZO2398
  • 348 POSTS
So just the strut mounts, not the whole part itself?
  • 52,797 POSTS
The part is new so it should be covered under warranty. Just send it back and get a new strut.
JGONZO2398
  • 348 POSTS
Turned out to be the front sway bar links, had my mechanic check it.
