Alarm goes off and door ajar mil light stays on
REDHEAD520
  • 2003 FORD EXPLORER
  • 4.6L
  • V8
  • 4WD
  • 200,000 MILES
My alarm will randomly start going off after I manually lock and shut my door, and it wont stop until I unlock my door with the key.
Also, my door ajar light is on everytime I start my vehicle, all doors are shut.
Do you
have the same problem?
Wednesday, August 21st, 2019 AT 9:07 AM
KEN
  • ADMIN
This sounds like the door latch on the drivers door might be worn out and needs replacement or you can see if the micro switch (pin switch) can be repaired or adjusted. The security system thinks the door is open or opened unexpectedly. Here are instructions on how to replace the latch check the pin switch first. Check out the diagrams (below). Please let us know what happens.
Thursday, August 22nd, 2019 AT 2:04 PM
