Heater problem
1997 Acura TL Engine Size unknown Automatic 4000 miles
where is the heater fan located. Fan would cut out then come on if I hit a bump. I am hoping it is aloose wire or a fuse.
Sunday, January 27th, 2008 AT 11:14 AM
JEREMIAH
MECHANIC
Its in the passenger front area, underneath the glove compartment. You don't have to open the glove compartment, just look under it. Fuse box is located right next to glove compartment too, open the passenger front door and pull the panel beside the glove box. Fuses are labeled behind the panel.
