Acura Integra brake warning light
ACURAMAN276
  • 1989 ACURA INTEGRA
Electrical problem
1989 Acura Integra 4 cyl Front Wheel Drive Automatic
when I press my brakes, the warning light comes on and I dont know why it does that. Also my horn doesn't work. My interior light doesn't work. And my lights wont flip down and I check all the fuses and they were good except I wasn't able to check the bigger fuses like the 50a and the 30a
Do you
have the same problem?
Saturday, November 28th, 2009 AT 4:22 PM
F4I_GUY
  • 3,302 POSTS
This sounds exactly like the brake fluid is low like you need font brakes
Saturday, November 28th, 2009 AT 5:02 PM
ACURAMAN276
I checked all the fuses inside the car and under the hood. Those other fuses I was referring to the 50a and the 30a im not sure if they are any good. Now everything I mention before worked at some point and time
Saturday, November 28th, 2009 AT 8:05 PM
KHLOW2008
  • 41,815 POSTS
To check the bigger fuses the easiest way is to use a grounded test lamp to probe either end to test for presence of voltage.
Your problem should not be with the main fuses. Since all fuses are ok, hope you tested with a test lamp, some bad fuse might look good visually, the next most likely fault would be the grounding of the circuit.
I believe not all the components failed at the same time and you could be having a few causes.
For the trunk light turning on with the brakes applied, check the taillight wire harness grounding ini trunk.
For the interior light, did you check the bulb? Does it turn on when the door ajar function is used or when switched on by the manual switch at the light?
As to hrn not working, did you test the horn and power supply to it? It could be the horns are faulty or a bad switch contact.
The headlights not closing could be due to the motor or its controlling circuit such as the switches oe relays.
Saturday, November 28th, 2009 AT 9:36 PM
MATTHEWJ
  • 1997 ACURA INTEGRA
  • 4 CYL
  • FWD
  • MANUAL
  • 260,000 MILES
1997 Acura Integra 4 cyl Front Wheel Drive Manual 260000 miles
When I started my car today the brake light on the dash came on (not sure if this is related or not) check the fluid level and its fine. When I went to turn my car off I could hear the starter still cranking. When I put the key to the on position (not the start position) the car starts right up. Because I am at work I tried stalling the car while it was running and the starter motor just putts the car along (in any gear). After leaving it running for 10 min or so I tried turning the car off again and it did. I am afraid to start my car to go for lunch in case it won't turn off again. Any idea what may cause the starter to stay engaged after the key has be turned off?
Thanks
Matt
Tuesday, January 24th, 2017 AT 5:09 AM (Merged)
LEGITIMATE007
  • 5,121 POSTS
Yes the ignition switch is faulty. What you can do in the mean time, is, when you want to turn the car off just disconnect the negative cable. But you need to change the ignition switch, better yet, before doing that, have someone check the reomote wire on the starter, check all the wiring from the battery to the starter, to the alternator for that matter.
MATTHEWJ
Thanks very much, I will start there.
Tuesday, January 24th, 2017 AT 5:10 AM (Merged)
LEGITIMATE007
  • 5,121 POSTS
Your quite welcome, keep me posted please
JUZBECUZ
  • 1998 ACURA INTEGRA
1998 Acura Integra
i CANNOT GET THE BRAKE LIGHTS TO COME ON AT ALL.
KHLOW2008
  • 41,815 POSTS
Hi juzbecuz,
Did you check the underhood fusebox for a blown stop light fuse?
The other possible cause would be a faulty brake switch located at brake pedal support.
BLADIMIR
  • 1994 ACURA INTEGRA
  • 274,770 MILES
I have a 1994 Acura integra and the Break light in the panel is on all of the time. It is ussualy on when you set the parking break and clears when you release the parking break, but now is on all of the time eaven if the parking break is not engage.
In addition, now the ABS light is on after the car runs for a wile.
Do you ahve any sugestions to clear this problem.
Thanks Bladimir
HMAC300
  • 48,606 POSTS
Take this to a pro so he can scan the abs system to see what is wrong with it. Your brake light may b on because of a bad master cylinder or leak in system.
