Fender replacement?
OSCARANDERSON
  • 2006 HONDA ACCORD
  • 2.1L
  • 4 CYL
  • MANUAL
  • 197,000 MILES
Im having trouble finding out what the piece is called that my fender bolts on to. I was recently in a wreck where I rear ended someone and my passenger side fender was smashed in, I was able to take it off but now I dont know how you would replace the metal part that is bent bc it doesnt unbolt.
Sunday, June 7th, 2015 AT 10:53 AM
CARADIODOC
  • 34,206 POSTS
You have to be sure it's aligned correctly, otherwise all the rest of the things that attach to it won't fit. You might be referring to the inner fender, To get a used part from a salvage yard, you'd have to buy a whole section of the body, the instructions for replacing the fender and inner liner are below. Check out the diagrams (Below). Let us know what happens and please upload pictures or videos of the problem.
Sunday, June 7th, 2015 AT 10:30 PM
SPENCER BRAGDON
  • 2002 HONDA ACCORD
  • 2.3L
  • 4 CYL
  • MANUAL
  • 2,323,233 MILES
Do I have to remove the door to tighten the bolt behind hinge area on my car listed above (coupe)?
Wednesday, December 30th, 2020 AT 11:38 AM (Merged)
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
Just a quick question first before we get started. Is the door hinge sagging/broke/loose or are you dealing with the hood hinge? Your post states your also talking about the fender. Thanks for using 2CarPros.
Danny-
SPENCER BRAGDON
Hi Danny, it is the bolt where the door jam is. Yes, I am talking about the fender removal/installation. Just wondering if I need to take the door off.
DANNY L
  • 5,648 POSTS
Hello again.
No, the door does not have to come off. Having the door open will give you some room but it will be a tight fit getting your hand in there. Hope this helps and feel free to ask any questions if needed. Thanks for using 2CarPros!
Danny-
DREAD09
  • 1999 HONDA ACCORD
  • 4 CYL
  • 150,000 MILES
How to change the right front fender of the car
KHLOW2008
  • 41,814 POSTS
Hi dread09,
You would need to remove the front bumper to gain access to some of the bolts benihd it. Removing the fender liner clips and holding bolts would allow you to take the bumper out.
JEEP27
  • 7 POSTS
  • 1999 HONDA ACCORD
  • 6 CYL
  • 300,000 MILES
Will a front fender and bumper from a 4 door 2001 Honda accord fit onto a 2 door 1999 Honda accord?
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Yes, those fenders are interchangeable and will fit between those years. Hope this helps and thanks for using 2CarPros.
DANNY L
  • 5,648 POSTS
Hello again.
I've attached picture steps below on how to replace the front bumper. Hope this helps and thanks again for using 2CarPros.
Danny-
