Daewoo Leganza 2002 with 52,000 miles
STEVE MUSSIGMAN
  • 2002 ALL OTHER MAKES ALL OTHER MODELS
The check engine light is on and the dealership told me it is a "cam sensor" and that it needs to be repalced. The cost is $200.00. Should I have this done?
Thank-you
Steve
Sunday, February 19th, 2006 AT 3:29 PM
PEPPERMRJ
  • 1,158 POSTS
I won't run properly if it is bad. It also wont pass emmision inspection.
About $85.00 for the part from an aftermarket supplier. The OEM part is usually more. Also not something I would recommend doing yourself.
Good luck.
Monday, February 20th, 2006 AT 8:30 PM
YOBOBYO
  • 17 POSTS
Yes, This has to be done, better sooner then later. $200.00 bucks isn't a bad price. You have to take the front of the motor off. Understand, your car will not pass smog if you don't get this done. Plus the car won't run very good eather. Your car could even stall. There was a recall on the cam sensor, you might want to check if your car falls within the recall. If it does, it was stated that the cam sensor could even catch fire.
Robert
Wednesday, October 8th, 2008 AT 1:31 AM
Related Check Engine Light Content
