How to Retrieve Subaru Codes OBD1 and Definitions
The Subaru OBD1 system is the predecessor to the OBD2 system the following is how you retrieve the codes with the code definition table below.
Locate the diagnostic connector which is located near the driver’s side kick panel, most cases, they maybe green or black.
  obd1 subaru test connector
Locate the computer which is located under the dash near the driver’s side.
With the ignition key in the on position and the engine off, connect the "read memory" connector and disconnect the "test mode" connector. The check engine light will start to blink, the first set of light blinks will be the first digit of the trouble code, there will be a short pause when the computer is going to output the second digit of the trouble code. For example; if the first set of check engine light blinks three times and the second set of flashing check engine light blink five times the code number is 35.
To clear trouble codes once the repairs have been made, remove the negative battery cable for 60 seconds, then reconnect.
Trouble Code Definitions
Code 11 Crank angle sensor fault
Code 12 Starter switch fault
Code 13 TDC sensor fault
Code 14 Injector no.1 fault
Code 15 Injector no.2 fault
Code 16 Injector no.3 fault
Code 21 Coolant temperature sensor fault
Code 23 Pressure sensor fault
Code 24 ISC solenoid valve fault
Code 26 Air temperature sensor fault
Code 32 Oxygen sensor fault
Code 33 Vehicle speed sensor fault
Code 35 Purge control solenoid fault
Code 36 Ignition circuit fault
Code 41 Air/fuel ratio control system fault
Code 42 Idle switch fault
Code 43 Throttle switch fault
Code 45 Atmospheric pressure sensor fault
Code 52 Clutch switch circuit fault
Code 62 Electric load signal fault
Code 63 Blower fan switch fault
Code 65 Vacuum pressure sensor fault
Code 111111 no codes
Questions?
If you have a car repair question, you can ask the 2CarPros community for help. We hope this guide helped you understand the repair. Please visit our 2CarPros YouTube channel for more helpful repair videos.
Repair Safety Notice: This guide is provided for general informational and educational purposes only. Vehicle repairs can involve risk of injury, property damage, or vehicle damage. Always follow proper safety procedures, use the correct tools, support the vehicle securely when raised, and consult a qualified automotive repair professional if you are unsure about any step.
