How to Test an Automotive Ignition System
 An ignition system ignites a fuel/air mixture inside the engine's combustion chamber at the optimal moment in the pistons compression stroke. This timing is designed to produce the most power while emitting the least amount of emissions. There are many configurations of ignition systems but all operate on the same principle, create a low energy field and collapse it onto a high energy coil that transfers electrical energy into the secondary ignition system, i.e. coil, wire and spark plug.
 The system is activated by the primary ignition system, most use a low voltage trigger system i.e. crankshaft position sensor (CKP). This low voltage system (1.0 to 2.0 volts) is increased to 12 volts by using an amplifier which is located inside of the computer or an externally mounted amplifier. The computer PCM (powertrain control module) controls the engine ignition timing by advancing or retarding the primary trigger signal.
Let's Jump In!
remove ignition coil safety
Step 5 - After the safety has been removed, depress the electrical connector tab to remove the connector from the coil assembly.
remove electrical connector
Step 6 - Once the connector has been removed, located both terminals to be used for testing.
connector test terminals
Step 7 - Because these terminals are small in size, sometimes a paperclip or small wire can be inserted into the connector terminals which makes testing easier.
Step 8 - After cutting the paperclip or wire, insert a piece into each terminal, do not allow the wires to contact each other, this could cause damage to the computer.
wire inserted into connector
Step 9 - Once both terminals have been prepared, use a voltmeter set to the DC voltage setting. Also install alligator clips to the leads to ensure a good connection.
voltmeter
Watch the Video!
Please watch this video of the job being done, then continue down the guide to glean additional helpful information.
Step 10 - Next, using the voltmeter lead clips, attach them to the paperclip wires, polarity doesn't need to be observed. (Note: Do not allow the leads to connect during the test.)
voltmeter leads connected
Step 11 - After connecting the leads, turn the ignition key to the "ON" position without cranking the engine. The voltage observed should be 0.
0 voltage
Step 12 - Then, crank the engine over while observing the meter, (engine should not start) the meter should pulsate between 0 and 12 volts. This is confirmation that the computer coil driver is sending signal to the coil for spark and that the ignition system is working. If no voltage is observed while the additional coils on the system operate, check for bad wiring, or computer. If none of the coil triggers operate suspect a crankshaft angle sensor (CKS), or computer control relay.
pulse voltage
Step 13 - Once this portion of the test is complete, remove the voltmeter leads and test pins from the coil electrical connector.
removing leads
Step 14 - With the electrical connector disconnected, remove the ignition coil mounting bolt.
remove ignition coil mounting bolt
Step 15 - After the mounting bolt has been removed, gently lift the coil from the plug well.
Step 16 - After gently removing the coil from the spark plug well, insect the coil for any broken pieces or cracks in the housing which are an indication of failure.
ignition coil
Step 17 - This next test will need a voltmeter set to ohms.
voltmeter ohms
Step 18 - With the coil removed, attach the voltmeter leads to either coil terminal ( small wire connector.)
connect voltmeter
Step 19 - Once the volt meter is connected obtain the reading provided, if this ignition coil was bad the reading would much higher.
coil ohms reading
Step 20 - After reconnecting the ignition coil to the wiring harness, observe the electrical contact which contacts the spark plug.
spark plug contact
Step 21 - For this portion of the test, a circuit test light is needed which is then connected to engine ground.
test light
Step 22 - While the grounded test light is creating an air gap between the spark plug contact or terminal, and the tip of the test light.
coil air gap
Step 23 - While keeping hands clear of the test area, have a helper crank the engine over, an electrical spark should be observed if the coil is functioning correctly. If no spark is observed the coil has failed and replacement is required.
electrical spark
Step 24 - After replacement or testing is complete, gently reinstall the coil into the spark plug well.
reinstall coil
Step 25 - Once the coil is in position, install the coil mounting bolt and tighten.
reinstall coil mounting bolt
Step 26 - After tightening the coil mounting bolt, reconnect the electrical connector onto the ignition coil. Once the job is complete, start the engine to check coil operation. If the check engine or service engine soon light is illuminated use a code reader to check for codes and reset the system.
reinstall connector
Questions?
Our certified technicians are ready to answer ignition spark questions for free. We hope you saved money and learned from this guide. We are creating a full set of car repair guides. Please subscribe to our 2CarPros YouTube channel and check back often for new videos which are uploaded regularly.
Repair Safety Notice: This guide is provided for general informational and educational purposes only. Vehicle repairs can involve risk of injury, property damage, or vehicle damage. Always follow proper safety procedures, use the correct tools, support the vehicle securely when raised, and consult a qualified automotive repair professional if you are unsure about any step.
