change the transmission fluid
2002 VOLVO S60
209,679 MILES • 2.4L • 5 CYL • TURBO • AWD • AUTOMATIC
TYINE28
Hi I have a 02 volvo s60 turbo awd I want to change the transmission fluid because it's black and thick but auto shops keep saying it's bad to flush it so what do I do.
Feb 24, 2016 at 4:44 PM
WRENCHTECH
  • CAR REPAIR CONTRIBUTOR
  • 20,761 POSTS
The problem is that you have waited too long. Changing it now can trigger a total failure by washing away the sludge that is helping seal the pressure that applies the clutches. You gotta do this sooner or not at all.
Feb 24, 2016 at 5:45 PM
TYINE28
So can I do it or is the car done for
Feb 24, 2016 at 7:54 PM
TYINE28
Can I change the transmission fluid or should I just junk the volvo
Feb 24, 2016 at 8:14 PM
WRENCHTECH
  • 20,761 POSTS
If you change it now you risk immediate and total failure. I would just leave it alone.
Feb 25, 2016 at 1:53 AM
JRAW692
My '01 v70xc ( turbo) had brown fluid after I bought it at 170,000. There was no evidence of it being changed ,ever, so I was very careful. I chose not to "flush" because it is debatable if it can help ANY CAR. I went with using full sythetic valvoline foriegn motors, then just drained and replaced fluid IN THE PAN ONLY. Drive then drain and repeat 3 times, that should put you're TF at nearly 100% new and no messing with the RAT( transmission cooler) or pan. I mean I put in the new filter but it's not critical.
Sep 12, 2019 at 6:56 AM
  • 54,350 POSTS
Excellent addition to this thread! Please feel free to help out whenever you are on the site :)
Sep 12, 2019 at 10:15 AM
ADEOLA
car parked for seven months,gear refused to select, flushing done and TF changed, no sjgn of TF flow from the gear. What can i do?
Sep 12, 2019 at 10:16 AM (Merged)
KHLOW2008
  • 41,814 POSTS
If transmission fluid is not flowing, then you caouls have a fault with the fluid pump. Get a pressure test done to confirm.
DANIELMARTIN007
Transmission problem
2001 Volvo S60 Two Wheel Drive Automatic 114000 miles
My car in the window says transmission service required?
JIS001
  • 3,412 POSTS
You should see if the Transmision Control Module is available for a software upgrade. You could have other sypmtoms aswell. Posted the following tech net.
A function called "Neutral Control" is present on all 2001 V70 and S60 cars. It is also present on 2002 non-turbo V70 and S60 cars built before January 2002. When the vehicle comes to a stop, the Transmission Control Module (TCM) activates Neutral Control. Even though the gear selector is in the Drive position, a Neutral condition is engaged hydraulically in the transmission. Neutral Control disengages when the brake pedal is released or the throttle is applied.
SYMPTOMS:
When the neutral control function is incorrect, there are three symptoms that can be felt in the car;
1. After coming to a complete stop and keeping the brakes applied, a "thump" can be felt in the car. It is felt about 2 seconds after coming to a stop.
2. When releasing the brake there is a harsh or double re-engagement of drive.
3. When idling in 'D' range with the brake applied, the engine speed oscillates (fluctuates).
In addition to these symptoms, some cars may set a DTC 012A or 012B in the TCM; which should be erased before downloading the software.
DANIELMARTIN007
[quote:108b382218="JIS001"]You should see if the Transmision Control Module is available for a software upgrade. You could have other sypmtoms aswell. Posted the following tech net.
SYMPTOMS:
In addition to these symptoms, some cars may set a DTC 012A or 012B in the TCM; which should be erased before downloading the software.[/quote:108b382218]
ALCLEL
2000 Volvo S60 Front Wheel Drive Automatic
Trans service required indicaded trans shifts in and out of gear at stops
VOLVO SERVICE ADV
  • 175 POSTS
Having a message indicates there is a fault in the transmission system. Best thing to do is taking it to the dealer for diagnostics. They can check for codes and check for a possible software upgrade for the "transmission control module".".
CENZONJO
Getting a text message: "Transmission Service Required" and "Check Engine". Car recently serviced. Transmission oil flushed and replaced. Running fine except for occasional slight surge forward after shifting to drive.,
JIS001
  • 3,412 POSTS
Anytime you replace the transmission oil you should have the counter reset also. Not doing so can cause false codes to set. What I would have done first in your case is have the dealer complete a transmission control module software upgrade.
