Fuel pump relay
2002 VOLKSWAGEN JETTA
DWAYNE LUCKEY
Electrical problem 4 cyl Front Wheel Drive Manual 148386 miles
where is my fuel pump relay so i can change it my car has p0261, p0267, p0270, p0264, p1425, p1117, p1435 the shop said get a new fuel pump relay that would take of the problem?
Jul 29, 2010 at 6:17 PM
  • CAR REPAIR CONTRIBUTOR
  • 54,354 POSTS
I have found these guides and diagram below that will help you check things out.
and
Diagram (Below)
Please let us know what happens so it will help others.
Cheers, Ken
Oct 13, 2017 at 4:25 PM
SAMER
Electrical problem
2004 Volkswagen Jetta 4 cyl Two Wheel Drive Automatic 69000 miles
Where are they located and what is the proper procedure to replace them?
Oct 13, 2017 at 4:25 PM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for donating
Your vehicle's fuel pump relay is located on the relay panel (under left side of dash). The fuse panel is behind the left side of dash, why are you needing to replace the entire fuse panel for? Do you mean just the fuel pump fuse?
SAMER
The above are two items are seperate items, that I need to replace.
How do i get to them and what is the proper procedure to remove and replace them?
Thank you!
BLUELIGHTNIN6
  • 16,542 POSTS
Okay, as stated before the fuel pump relay is located under the left side of the dash. Will have to get underneath there and check it out to find it, just pull it from it's mounting location and disconnect electrical connector to replace. The fuse panel is behind the left side of the dash as well. first disconnect the battery for safety. Remove the fuse panel cover and disconnect all of the electrical connectors. Once connectors on disconnected just remove any bolt(s) holding the panel in place and then remove panel to replace.
DISARRAY
Electrical problem
2001 Volkswagen Jetta 6 cyl Front Wheel Drive Automatic 79559 miles
where would the fuel pump relay be located on a 2001 VW jetta VR6?
Here you go
https://images.2carpros.com/forum/automotive_pictures/12900_fuel_pump_relay_volks_1.jpg
ADRIANCARLOS
Other Category problem
2001 Volkswagen Jetta 4 cyl Wheel Drive Type unknown Automatic 130000 miles
Anyone know where the fuel pump relay is located on a 2001 VW Jetta. I need to find it so can determine if thats bad or if not i know have a bad fuel pump it just stoped pumping gas to power up the car no gas going thru to injectors.
WILLIS24
I have the same problem, did you figure anything out?
Anyone know where the fuel pump relay is located on a 2001 VW Jetta. I need to find it so can determine if thats bad or if not i know have a bad fuel pump it just stoped pumping gas to power up the car no gas going thru to injectors.[/quote]
ADRIANCARLOS
[quote:dea7e1100e="Willis24"]I have the same problem, did you figure anything out?
Anyone know where the fuel pump relay is located on a 2001 VW Jetta. I need to find it so can determine if thats bad or if not i know have a bad fuel pump it just stoped pumping gas to power up the car no gas going thru to injectors.[/quote:dea7e1100e][/quote]
Yeah i got it working the fuel pump realy is under the steering wheel theres a few relay fuses under you have to remove the plastic cover i replaced it but i just returned it to back toAuto Zone. But that was not the problem it was the fuel pump that was bad i replaced it. Its easy its under the right hand back seat it took me 20mts to change it you have to make sure you discinnect the battery before you remove the fuel pump. the pump cost on line $250 dls at Stopshopanddrive.com
