1996 Volkswagen Jetta Repair Question
Asked on August 1, 2010
Relay marker # ' s
1996 Volkswagen Jetta 4 cyl Two Wheel Drive Automatic 120000 miles
Thank You for your reply but as stated in original question I need to also know the fuse relay marker #'s as I moved some of them.Now I know the relays location but not the actual marker #'s for each relay.Please reply .., Thank You p/s.., I hate to keep bothering you but if you look at the original question I still do not know the relay numbers stamped on the back of them.
Answer
Replied on August 1, 2010
Sir-I hope this is what you are looking for-see below:
Fuse Location
Fuse locations for options not shown can be found in the corresponding wiring diagrams.
Amp.
1 - Headlight, Low Beam, Left (56b) 10
2 - Headlight, Low Beam, Right (56b) 10
3 - License Plate Lights (58) 10
4 - Rear Window Wiper And Washer System 15
5 - Windshield Wiper/Washer 15
6 - Fresh Air Blower, A/C (X) 20
7 - Tail Lights, Right (58R) 10
8 - Tail Lights, Left (58L) 10
9 - Rear Window Defogger 20
10 - Fog Lights 15
11 - Headlight, High Beam, Left (56a) 10
12 - Headlight, High Beam, Right (56a) 10
13 - Horn (15) 10
14 - Back-Up Lights 10
15 - Engine Electronics (15) 10
16 - Power Sunroof, Front Map/Reading Light 15
17 - Emergency Flashers (15) 10
18 - Fuel Pump (FP), Heated Oxygen Sensor (HO2S)
Control Module 20
19 - Coolant Fan, A/C Relay (30) 30
20 - Brake Lights (30) 10
21 - Interior Lights, Clock, Luggage Compartment
Light (30) 15
22 - Cigarette Lighter, Radio, Luggage Compartment
Release 10
Separate Fuses
(Located above the relays)
- Fuse for ABS hydraulic pump relay 30
- Fuse for ABS main relay 30
- Fuse for A/C 30
- Fuse for power windows 20
- Fuse for cruise control 5
- Fuse for cigarette lighter 15
In the engine compartment above the brake booster:
- Glow plugs 50
Note: The Glow plug fuse should be changed by your authorized Volkswagen dealer only.
http://www.2carpros.com/kpages/auto_repair_manuals_alldata.htm
