2CarPros - Car Questions & Answers
2004 Vauxhall Meriva Repair Question
Topics covered: Battery, Engine, Alternator.
Asked on September 30, 2009
2004 Vauxhall Meriva fault when engine warm
Electrical problem
2004 Vauxhall Meriva 4 cyl Two Wheel Drive Manual 70000 miles
After 10 mins running, the alternator warning light comes on, my rev counter and speedo drop to zero and intermittently come back on again, (alt light stays on) then if i stop engine, car wont start again, (although turns over fine) until engine is cold again. My battery voltage is 14,4 volts when running and 12,5 ish when engine off. Any ideas?
Avatar Asked by DomeOfChrome
Answer
Replied on September 30, 2009
try replacing the alternator ,, it may be faulty when hot and not chargeing ... but chargeing the battery again once cooled down !!
Tiny Answered by Dave H (expert)
13,682 answers provided
Replied on October 1, 2009
Thanks for your reply, I was sort of disregarding the alternator as when Ive got the fault on running engine Im getting a higher battery voltage than when the engine is stopped. Is it possible for this if alternator isn`t charging?
Tiny Response from DomeOfChrome
1 question asked
14.4 volts with engine running is a good alternator ..if the battery/alternator light is
ON and you are still getting 14.4 volts at the battery then you must have a bad wire somewhere ? does the car show the MIL (malfunction indicator light) on the dash display !! have you checked for any fault codes ?
No other lights showing and no faults have been registered or stored. What I find strange is fact that car wont start for about 3 hours after the fault shows.
1 question asked
Replied on November 6, 2009
My car had exactly the same problem with the speed dial and battery warning light, also the traction control light was on too.
Went to the Vauxhall dealer, non of these things were actually faults (happened to find an oil leak while doing this though) they reset the fault codes and it was fine for about a week. Then the oil light came on, apparently related to not resetting a fault code when fixing the leak, which was then sorted. Now, a day later the battery and traction control lights are on (intermittantly) again, but this time (so far) the speedo's ok.
Did you ever get to the bottom of this problem? It would be nice to be able to trust the warning lights again.
Tiny Answered by soniacaldwell
0 questions asked
Thanks for your reply, Im still not at the bottom of the problem and car has been in and out of Vauxhall garage over the past month. Now waiting on new ECU - engine control unit (for last 2 weeks) to see if problem is solved.
1 question asked
Replied on November 25, 2009
Sonia, Car now OK after REPAIR of my ECU as Vauxhall dealer couldnt get new ECU. Car now traded in.
1 question asked
