Mechanics
WONT START
1987 Toyota Cressida
Engine Mechanical problem
1987 Toyota Cressida 6 cyl Two Wheel Drive Automatic 196, 00 miles
The car turns over but will not start. Have checked the plugs, wiring, vaccume lines, what s wrong?
TRA-C
January 14, 2010.
Cranks and no start
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Rasmataz
Jan 14, 2010.
