2CarPros - Car Questions & Answers
Toyota Corolla Repair Question
Topics covered: Radiator, Coolant, Coolant leak.
Asked on May 10, 2006
Small coolant leak
I have a 1992 Toyota Corolla with 130,000 miles on it. I just noticed a small coolant leak coming from under driver's side of radiator. It is a slow drip and I have added more coolant twice in the past two days. The car is not overheating, but I'm afraid it might start to if coolant runs too low. I have an estimate on cost of parts, but what is a typical charge to replace a radiator. If it isn't the radiator, are there any other parts that I should check?
Avatar Asked by mallegni
Answer
Replied on May 10, 2006
It is an easy job but you should replace both upper and lower hoses and the thermostat. Labor about $100.00 see the attached for radiator prices. You do have a choice between plastic and metal.
http://replacement.autopartswarehouse.com/parts/autopartswarehouse/quote.jsp?year=1992&product=G1000-66478&application=000641878&part=Radiator&dp=true
Tiny Answered by losone
7 questions asked
