1995 Toyota Corolla Repair Question
Topics covered: Cigarette lighter, Fuse, Speedometer.
Asked on January 25, 2009
1995 Toyota Corolla why does the cigarette lighter not work
Electrical problem
1995 Toyota Corolla 4 cyl Front Wheel Drive Manual 100000 miles
the cigarette lighter and speedometer light not work, we checked the fuses, and they are all okay.
Answer
Replied on January 26, 2009
Cigarette lighter should only work when ign. is on, remove and check for 12V at connector. If no voltage at connector then there is a fuse blown.
Speedometer may be a bad sender, or cable if it uses cables.
