2CarPros - Car Questions & Answers
1987 Toyota Corolla Repair Question
Topics covered: Camshaft, Timing belt, Engine.
Asked on February 27, 2008
1987 Toyota Corolla REPLACING CAMSHAFTS
Replied on February 29, 2008
could you be more specific about this "service bolt"? The specs for the bolt are shown in the Auto Zone document - but i'm not clear on it's purpose. Aren't we bolting together two items (gear and subgear) that are already attached via a lock washer?
Lucky
Tiny Response from luckyjs
2 questions asked
Lucky[/quote:5b3002dd2f]
Yes, but for me it gives me a good reference point and you would need it to remove the subgear. The service bolt is an M6 x 1.0 bolt about 15mm long. It cannot be put in at the timing position because the head casting is in the way, so you rotate the cams to install it.
If you rotate the exhaust camshaft (cresent wrench on square camshaft boss) so that the pulley mark is at 12:00, the service bolt hole is at 9:00 and the OUTSIDE (timing belt side) marks on the camshafts are pointing at each other, you are in good shape and can install the timing belt, the inside camshaft marks are installation marks not timing marks.
otherwise:
You have to remove the intake camshaft.
Position the exhaust camshaft so that the knock pin is just above 9:00 Do this by rotating the camshaft with a cresent wrench on one of the square castings on the camshaft. There is a prior step, but the exhaust camshaft is already installed.
Mesh the intake and exhaust by matching the installing marks (dots on the inside of each camshaft).
Roll the intake cam into position, install bearing caps. I tighten from center out in 1/4 turn increments.
Remove service bolt and then rotate the camshafts into timing position with a cresent wrench on the square boss of the exhaust camshaft (Haynes manual does not specifically say this that I can find)
Timing position would be the service bolt hole at 9:00, the timing marks on the FRONT (not inside) of the camshafts would be pointing at each other, and the hole in the timing belt pulley would be at 12:00. Then you can install the timing belt, just make sure the lower belt cog timing mark is pointing at timing mark on the oil pump.
This make sense?
Tiny Answered by mmprince4000 (expert)
8,853 answers provided
Thanks!
I believe I've got it now. I can't get to the car until Saturday, but will print and take your message with me for reference.
Lucky
2 questions asked
Replied on March 9, 2008
THANK YOU for all your expert help.
Learning about that second set of marks was all it took (as in: it was right in the first place, but I just couldn't SEE it!)
I apologize for the delay in posting this. I am a Pancreatic Cancer patient at UCLA Medical Center and sometimes get a bit knocked down for a few days after chemo treatments.
The car is completed, my sister-in-law is thrilled and says it hasn't run this well in a very long time.
THANKS AGAIN!
Lucky
2 questions asked
