2CarPros - Car Questions & Answers
1997 Toyota Camry Repair Question
Topics covered: Timing belt, Engine, Mechanic.
Asked on December 17, 2008
1997 Toyota Camry need timing mark alingment
Engine Mechanical problem
1997 Toyota Camry 4 cyl Two Wheel Drive Automatic 170000 miles
i need a timing mark alingment for my car my timing belt broke and i guess the guys needs the timing mark alingment sheet
Avatar Asked by jaylenmiah
Answer
Replied on December 17, 2008
On the crank pulley there is a "V" cut out on the pulley, align to zero on plastic cover. On the top pulley there should be a hole in the pulley spokes, behind the pulley you should see a notch (groove) , line that up with the hole, use a mirror to look inside the hole aligning to the notch and put timing belt on careful not to turn pulleys.
http://www.2carpros.com/forum/automotive_pictures/89255_timing_1.gif
Tiny Answered by dsplc
2 questions asked
