car rpm goes up and down sometimes car dies out at light when I have stop and then I start to drive iit hasitates then takes off is the distrbutor bad I changed spark plugs and wires gave it a tune up
Sunday, September 19th, 2010 AT 12:09 AM
MECHANIC
Hi stephaniewsh@aol. Com, Welcome to 2carpros and TY for the donation
Clean out the idle air control valve and EGR and PCV valves and then test the throttle position sensor and aiflow meter-also check the fuel pressure-Let me know
SPONSORED LINKS
Sunday, September 19th, 2010 AT 3:44 AM
STEPHANIEWSH
MEMBER
Thank you I will try that and let you know what happens
