Auto Door Locking Function
CREBILLARD
  • 2000 TOYOTA AVALON
  • 6 CYL
  • FWD
  • 68,000 MILES
My 2000 Toyota Avalon has an auto door locking function (all doors lock automatically when the shift lever is moved out of "P" postion and the brake pedal is released). My owner's manual says this can be disabled - "consult your Toyota dealer for details". When I first bought the car, I did have it disabled, but in January we had a cold snap and this function became enabled again. Not sure if the cold was the cause or just a coincidence. At any rate, how can I disable it so that I don't have to pay the dealer to do it?
Sunday, February 6th, 2011 AT 2:20 PM
TOYODAMASTERTECH
  • 25 POSTS
With ignition switch in ON position, open driver's door. Turn ignition switch off, repeat inserting and removing ignition key into/from ignition lock cylinder 5 times and turning ignition lock on and off 5 times within 10 seconds.
Press unlock side of door lock manual switch 5 times within 10 seconds after completion of step 1. The function is deactivated 10 seconds later.
Cheers
Wednesday, February 16th, 2011 AT 4:21 AM
CREBILLARD
Thanks! I'll give it a try.
Thursday, February 17th, 2011 AT 12:15 AM
BLUESTAR50
  • 6 CYL
  • FWD
  • 72,000 MILES
I would like to deactivate the automatic door lock feature so the doors do not automatically lock when I start the car. Could you please help me.
Saturday, August 11th, 2018 AT 3:19 PM (Merged)
KHLOW2008
  • 41,814 POSTS
Hi bluestar50,
Thank you for the donation.
I tried to find for Avalon but was not able to get any data on resetting but managed to find on Camry, so no promise it will do.
1. Close all doors.
2. With ignition switch turned to "ON", open driver's door.
3. Within 10 seconds repeat the following 5 tiimes.
Turn ignition switch "OFF", remove key, insert key, turn Ignition switch "ON".
(repeat 5 times in 10 seconds )
4. Press unlock side of door lock manual switch 5 times within 10 seconds after completion of steps 1 to 3 above. The function should be deactivated 10 seconds later.
Repeat process if necessary.
