Fuel pump relay location please
2002 SUBARU OUTBACK
KSULLY47
I need to know the location of my fuel pump relay?
Nov 15, 2011 at 6:01 PM
  • CAR REPAIR CONTRIBUTOR
Here is the fuse panel diagrams as well the relay is located under the dash on the driver s side.
Check out the diagrams (Below) Please let us know if you need anything else to get the problem fixed.
Nov 15, 2011 at 6:06 PM
CDUBYA2003
I replaced the fuel pump last month and it has stopped working. Using a multimeter, I checked the harness at the fuel pump to see if it was getting power, which it was not. I then checked all fuses in the vehicle (checked continuity with a meter and then Visually inspected each fuse in case both sides of the fuse were grounded) but all fuses checked out okay. I have three questions:
1) Is there a fuel pump fuse? If so, where is it located? (I don't have an owner's manual)
2) where is the fuel pump relay located
3) should the wires at the fuel pump have continuity with each other? (the 12 volt and ground input wires at the pump)
The reason I ask the third question is because I believe these wires are not supposed to be 'touching'. Since the two wires are touching, this would probably indicate that the pump went bad and in turn caused the two wires to touch, which would ultimately blow a fuse or possibly damage the fuel pump relay.
What do you think?
Thanks!
Apr 4, 2018 at 4:25 PM (Merged)
3) should the wires at the fuel pump have continuity with each other? (the 12 volt and ground input wires at the pump) You're measuring across the fuel pump motor windings you should get a continuity Check fuse no. 16 and see below
https://images.2carpros.com/forum/automotive_pictures/12900_fuel_pum_fuse_and_relay_location_2.jpg
SCOUT2494
  • 12 POSTS
The relay ure pointing at beside the fuse box is the wrong relay the relay atop of the relay is the fuel relay! i can`t find the fuel pump relay.
Nov 11, 2019 at 5:54 PM (Merged)
Attached is the information that is provided in the service manual. Let me know if you need more information. Thanks
SCOUT2494
  • 12 POSTS
is it located under the dash and where would it be? please let me know.
  • 54,350 POSTS
It is #4 in diagrams above. Can you see it? click images under the the "IMAGES (CLICK TO ENLARGE)" text. Please let us know if you need anything else to get the problem fixed.
SCOUT2494
  • 12 POSTS
fuel pressure regulator how can i test it to make sure it`s working
Nov 11, 2019 at 6:01 PM
  • 54,350 POSTS
Connect a fuel pressure gauge and with the engine running disconnect the vacuum line the pressure should go up. Here is a guide to help:
Nov 14, 2019 at 11:06 AM
