When you turn the key to start the car, no light comes on?
SIMON FELI
  • 2006 NISSAN ALMERA
  • 1.6L
  • 4 CYL
  • MANUAL
  • 190 MILES
When you turn the key to start the car, no light comes on in the small window on in that small window on the dashboard, only the battery light shows. The engine search light does not come on.
Tuesday, September 24th, 2019 AT 7:34 AM
SCGRANTURISMO
  • 4,897 POSTS
This sounds like the starter is having problems or the battery needs to be load tested these guides can help us fix it.
and
Wednesday, September 25th, 2019 AT 3:03 AM
SIMON FELI
Thanks.
The problem was about a the battery I got a new one starts right up
Simon
Thursday, September 26th, 2019 AT 10:22 AM
ISAAC SEUNA MOTSUMI
  • 2005 NISSAN ALMERA
  • 1.6L
  • 4 CYL
  • MANUAL
  • 125,853 MILES
The car does not light check engine light so it does not want to start.
Thursday, March 11th, 2021 AT 6:56 PM (Merged)
  • 108,328 POSTS
There are many different things which can cause a no start situation on a vehicle. Take a look through this link. It discusses the most common reasons for a no start and explains how to check different things.
Let me know if that helps. If you have other questions, need help, or just need more information,let me know.
RATFACE
  • 2002 NISSAN ALMERA
  • 650,000 MILES
How many hours to replace a starter motor in a 2002 nissan almera is it difficult to get at, do I need to remove the exuast pipe to get at it. Do I need special tools. Would it bee better to get a mechanic to do the job and how many hours would he take. I cant stretch this question any further. Ratface
Thursday, March 11th, 2021 AT 6:57 PM (Merged)
HMAC300
  • 48,601 POSTS
Sounds like the starter is bad. Here is a guide to help you step by step with instructions in the diagrams below to show you how on your car.
