Stall, throttle response loss mid operating temperature
VOPRO
  • 15 POSTS
Still no codes. No change with new Throttle Body. Always about the 170-180 temperature (mid-way of warm up cycle). A/C is always on but I don’t believe it’s happening as a result of the compressor coming on. Alternator seems to have good numbers as well. I would have sworn the Throttle Body would have fixed it but, nope. So wired.
Thursday, May 14th, 2020 AT 7:15 PM
  • 108,498 POSTS
I have to be honest, it has me stumped. The only thing I can think of now is the module I mentioned.
Thursday, May 14th, 2020 AT 7:45 PM
VOPRO
  • 15 POSTS
Well that actually makes me feel better! I tried to follow the issue and address it based on the info I had along the way. Now that I’ve exhausted that, I came here. If it has you scratching your head then I really have exhausted all Avenues.
I’ll keep at it and if I find anything further I’ll touch base just so you will know for the future if you deal with anything like it again. You have been awesome and I truly appreciate your time and effort!
Friday, May 15th, 2020 AT 4:16 AM
  • 108,498 POSTS
The only thing I find a bit odd is the idle speed. You said it's at 550 when normal. That is even low. I'm questioning if the control module needs flashed.
It's just a thought. A dealer wound need to do that for you. I appreciate you getting back with me. And yes, I would love to know what you find. Chances are it will help others in the future as well.
Friday, May 15th, 2020 AT 8:14 PM
