Clutch problem?
DIRUNGARAY
  • 2005 SATURN VUE
  • 125,000 MILES
Hi, I have a 2005 saturn vue awd van, 3.5L V6 engine has been running perfectly until a couple of days while on the road when I stopped and then had to revolutionize much speed for movement, the moment I stopped returned again and not moving.
the vehicle must be switched off briefly and then on again to return to work, besides it makes a strange sound (like a car mechanic is not pressed the clutch to get good speed) and has an almost constant buzz.
may be solved with something like a master rebuilding kit.
I can do?
Friday, February 10th, 2012 AT 2:50 PM
SATURNTECH9
  • 30,869 POSTS
We need to something straight here if you have a 3.5L engine then you dont have the cvt transmission in there. So do you have the V6 or 4cyl engine?Also any codes?
Friday, February 10th, 2012 AT 4:33 PM
DIRUNGARAY
Its a 3.5L All wheel drive saturn vue 2005
Saturday, February 11th, 2012 AT 3:09 AM
SATURNTECH9
  • 30,869 POSTS
Only the 4cyl vues came with the cvt transmission you have the honda combo. Do you have any codes in the computer?
Sunday, February 12th, 2012 AT 2:41 AM
DANIEOPARA
  • 2003 SATURN VUE
  • 4 CYL
  • MANUAL
  • 167,000 MILES
Drove my car on a 100miles trip, without having any problem. The next day, stepped on my clutch felt all the pressure were gone. The car allows me to starts it but cant put my car in gear. I looked at my clutch oil, and it was dry. Went to go get more oil and added it to it. I will like to know if that's the problem and how long would it take to get back to it's normal operational function after oil is been added.
Wednesday, November 13th, 2019 AT 9:56 AM (Merged)
  • 31,937 POSTS
Hi there,
You will more than likely have a leak at the clutch slave cylinder, this will have to be checked first, you will have to re bleed the system as it will be full of air, every time you push the clutch some fluid is lost, so you will be back to where you are now sooner rather than later, check the slave & the master for signs of leaking.
Mark (mhpautos)
