Hep my Pontiac Spain
REGGAEMAN
  • 17 POSTS
https://www.2carpros.com/forum/automotive_pictures/73364_IMG_0002_1.jpg
it arrives at the right next to the pedal sees the Connector.
Monday, May 21st, 2007 AT 3:27 PM
REGGAEMAN
  • 17 POSTS
After leaving the car the factory, after making change of oil and filters light SERVICE ENGINE SOON no longer ignites but it has symptoms such. When I take the perfect car in the morning the first 15 minutes but later it is extinguished when it wants gives pulls, not that to do. Here down you have a photo of the motor but it is of little aid.
https://www.2carpros.com/forum/automotive_pictures/73364_IMG_0003_1.jpg
Monday, May 21st, 2007 AT 3:54 PM
SERVICE WRITER
  • 9,123 POSTS
You can try unplugging the MAF sensor and driving the car, or unplugging the MAP sensor and driving the car.
Usted puede tratar de desenchufar el sensor MAF y conducir el coche, o desenchufar el sensor de MAPA y conducir el coche.
https://www.2carpros.com/forum/automotive_pictures/30961_mafpon_1.jpg
https://www.2carpros.com/forum/automotive_pictures/30961_mappon_1.jpg
Thursday, May 24th, 2007 AT 4:55 AM
REGGAEMAN
  • 17 POSTS
Thanks I will try, let's see if there is a solution, thanks for your help.
Thursday, May 24th, 2007 AT 4:25 PM
REGGAEMAN
  • 17 POSTS
Good proven the one of the sensor the car goes well but all the accelerated short while to two thousand revolutions remains. All the short while accelerated to 2000
Tuesday, May 29th, 2007 AT 5:18 AM
SERVICE WRITER
  • 9,123 POSTS
https://www.2carpros.com/forum/automotive_pictures/30961_firebirdvac_1.jpg
need good vacuum.
necesite el vacà o bueno.
did the sensor get replaced? Was the sensor bad? Which one?
 se hizo el sensor sustituido?  Era el sensor mal?  Cuà l?
Tuesday, May 29th, 2007 AT 8:49 PM
SERVICE WRITER
  • 9,123 POSTS
Did the sensor get replaced? Was the sensor bad? Which one?
MAP or MAF?
Tuesday, May 29th, 2007 AT 8:57 PM
REGGAEMAN
  • 17 POSTS
The sensor that you showed to me in the previous photo, disconnects it, and when it takes the car it was accelerated to 2000 revolutions.
Wednesday, May 30th, 2007 AT 5:27 AM
SERVICE WRITER
  • 9,123 POSTS
Disconnected the maf sensor?
Electronically, with the electrical connector correct?
Clean the sensor
 desconectado el sensor maf?
 electrà nicamente? Â, Con el conector eléctrico correcto?
Limpie el sensor.
Saturday, June 2nd, 2007 AT 8:22 AM
REGGAEMAN
  • 17 POSTS
I am going to take the car to the factory, tell me that things must review the mechanic. Because here in Spain they do not know much that to watch. It tell me that things must review for I to say to him. On the sensor if I disconnect it it is accelerated continuously 2000Rpm.
Tuesday, June 26th, 2007 AT 3:40 AM
REGGAEMAN
  • 17 POSTS
Thursday, July 5th, 2007 AT 2:50 PM
SERVICE WRITER
  • 9,123 POSTS
I'm sorry that I am not helping much, but the language barrier and what info I have is leaving me without answers.
Thursday, July 5th, 2007 AT 3:23 PM
FISHERMAN
  • 937 POSTS
Hey Paul!
You do it good !
I think the name of the parts were the problem !
But. The rest of the thread looks perfect for me!
Reggaeman !
Llevaste tu vehiculo al taller de la agencia?
O lo pudiste reparar tu mismo?
Leiste la computadora de tu carro para sacar los datos?
Se que alla en Espana no existen muchos vehiculos Americanos y que a lo mejor tuviste problemas pero si aun no lo has reparado dejamelo saber y Paul y Yo te ayudaremos.
Gracias y espero que estes bien!
Wednesday, October 17th, 2007 AT 9:18 AM
