Shift Solenoid Valve B
NKERSTIENS
  • 2000 PONTIAC GRAND PRIX
  • 6 CYL
  • FWD
  • 97,500 MILES
We are trying to replace this sensor, and we cant seem to find it. We have the pan and oil off the car. It is a 2000 Pontiac Grand Prix GT V6 Engine.
Sunday, July 31st, 2011 AT 7:57 PM
  • 108,192 POSTS
You need to remove the transmission oil pan here is a gide that can help.
Cheers
Sunday, October 9th, 2011 AT 5:37 AM
HGL
  • 6 CYL
  • FWD
  • 200,000 MILES
Can I remove the transmission pan to accesss and replace this solenoid?
Howard
updated 4/24/09
By this diagram solenoids are outside the transmission.
Thursday, October 4th, 2018 AT 3:57 PM (Merged)
MMPRINCE4000
  • 8,549 POSTS
Which one?
https://www.2carpros.com/forum/automotive_pictures/108325_GP_solenoid_1.jpg
MMPRINCE4000
  • 8,549 POSTS
Yes, as the pic shows, however, there may be some in pan or enclosed. Try to identify each one visually.
TRUSSELLJK
  • 6 POSTS
  • 1993 PONTIAC GRAND PRIX
  • FWD
  • 100,000 MILES
How to change a shift solenoid on a 93 pontiac grand prix le
DOCFIXIT
  • 18,828 POSTS
They are on the valve body need to remove fluid and pan. Not a novice repair
TRUSSELLJK
  • 6 POSTS
There are no sencor in the bottum pan could it b in side pan if so how do we get to it?
DOCFIXIT
  • 18,828 POSTS
Yes side cover DO NOT let check balls fall out on removal
TRUSSELLJK
  • 6 POSTS
K thanks but one more? Do we have to totally drop the k frame or can we do it part of the way
DOCFIXIT
  • 18,828 POSTS
Part way and should be able to remove solenoid without removal of body. Is it "A" or "B"?
TRUSSELLJK
  • 6 POSTS
Im not to sure how can ya tell?
DOCFIXIT
  • 18,828 POSTS
Why are you wanting to chang? Was there a trans code?
TRUSSELLJK
  • 6 POSTS
Ther is no code but when get in to 3rd it will not shift down and when u stop it will kill engine and you can start it again but as soon as u put it back in gear it will kill it again and we have done everything else u can do to it and thats the last optionis the sencor
DOCFIXIT
  • 18,828 POSTS
If it was a solenoid a code would be set. Suapect torque converter is locked up
TRUSSELLJK
  • 6 POSTS
Thats what we wer starting to thank but my dad told us to try the solenooid first to see
