Engine high idle?
IGOR
  • 1999 PONTIAC GRAND AM
  • 4 CYL
  • 100,000 MILES
My wife's car (a 1999 Grand Am 4 cylinder automatic trans) idles around 400 rpm and dies frequently. How do I bump the idle up to 800-1000 rpm where it should be?
Do you
have the same problem?
Sunday, November 28th, 2010 AT 12:34 AM
HMAC300
  • 48,601 POSTS
Try cleaning the throttle plate on both sides with choke cleaner first and the oblong hole where the idle air control is. there is no adjustment.if it still does it after that take the choke cleaner and spray around the inlet manifold by the head. if the idle picks up you need a new inlet gasket.
This guide can help us fix it.
https://www.2carpros.com/articles/engine-idles-too-high
Sunday, November 28th, 2010 AT 1:34 AM
CHRISTI992
  • 11 POSTS
  • 1998 PONTIAC GRAND AM
I have a 98 Pontiac Grand Am with a 3.1 with 100K miles. It has been idling up recently and no matter what will not idle down until I turn it off several times. I replaced the MAP sensor (like a mechanic told me to do) and it seemed to help for a while, but it went back the the same prob. (Also the brakes are very hard to push when it is revved up. So I was thinking a vacuum leak. But have not found one) The other more annoying problem I am having with this car is it just dies going down the road. I have to pull over and turn the car off, then restart it. It usually restarts, but sometimes does not. No one knows what is wrong with it. I have four kids and cannot be stuck on the side of the road. I need help with this please!
Tuesday, June 23rd, 2020 AT 1:50 PM (Merged)
BMRFIXIT
  • 19,053 POSTS
Hello
Do you have check engine light coming on?
Brake paddle very hard
check the vacuum supply to booster
If supply is good unplug the vacuum from the booster and seal the vacuum
start car check the idle
Good luck
CHRISTI992
  • 11 POSTS
The Check engine light is on. I have had it tested and it says misfire on number 3. It has been like this for a while. I have replaced plugs wires and coil pack.
BMRFIXIT
  • 19,053 POSTS
Not every misfire is a spark problem
Check vacuum leaks injector engine compression
DRUMTECH
  • 1997 PONTIAC GRAND AM
  • 115,000 MILES
This problem started with the idle at 4,000rpm. I replaced the throttle control sensor which made no difference. I removed the throttle body, cleaned it out with carb cleaner, especially where the IAC comes in (I think that is where the main problem was). I checked vacuum lines. I replaced the gasket, changed the spark plugs, wires, air filter, and oil, but it is still idling from between 1,000 - 1,600. How do I get it to idle at 800rpm? Is there something else I can do. The check engine light is on, when it goes through the test, it pretty much says there is an issue, but not specific. Where should I look next? If there is a vaccum line that would most directly impact this, which one would it be? Thanks for your help guys!
Tuesday, June 23rd, 2020 AT 1:51 PM (Merged)
You need to check all vacuum hoses for leakage and also clean out IACV and see what happens
CARADIODOC
  • 33,699 POSTS
When the engine is still cold, spray water on the intake manifold gasket(s) and vacuum hoses. Watch for any place where it gets sucked in or where it makes the engine slow down momentarily. You can also pinch off various vacuum hoses to see if one brings the idle speed down. If you find one, follow it to its branches, then pinch each one to follow it to the leak.
KCIR
  • 4 CYL
I have a 97 Grand Am that has a high rpm starting problem. What can I do to keep it from idling so high?
  • 108,005 POSTS
How high does it go? Do the rpm's go up and down while sitting? Has the check engine light come on?
KCIR
Yes, the enine light was on; but recent repair(replacing idle air contol motor) reset codes(p0107, p0141, p0172, p0506)and engine light is now off. It goes to 3500 rpms, then calms down to 1000 rpms after putting in gear with foot on brake. This cycle must be repeated again; then it's normal until the car is turned off again. It happens when the car is hot or cold.
MATHCARL
  • 4 CYL
  • FWD
  • MANUAL
  • 257,000 MILES
I have 1997 grand am gt with a 2.4L manual trans the car runs good at an idle get up to 55 mph while it has a load on it runs good when it levels off on straight away it starts bucking about 4or 5times before straightens out and continues to do it every time after you put a load on it any help would be appreciated Thanks
  • 108,005 POSTS
HAs the check engine light ever come on? Have you checked fuel pump pressure? Here is a how to if you need it:
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Let me know what you find.
MATHCARL
No the check engine light has never come on but a new fuel pump and fuel filter was installed about 4 months ago
  • 108,005 POSTS
If the fuel pressure is good, and there is no check engine light, there has to be a vacuum leak or the catylatic converter is starting to plug. Have those items been checked?
MATHCARL
No, but I will check those things and see what I get
  • 108,005 POSTS
SMITHBEY
  • 1996 PONTIAC GRAND AM
  • 4 CYL
  • 169 MILES
I have been experiencing high RPM's that remain steady when I go 65-70 MPH and the RPM'S remain high until I let up off the gas a little. There is an exhaust leak in the car too.
Another thing that is happening is the car is slow to accelerate from a stop position. And the check engine light is on also.
MIKE H R
  • 3,094 POSTS
Have the car scanned to see what is causing the high rms. Also check around the exhaust leak to see if there is a wire touch or burnt. With reference to the exhaust leak I would have it repaired, If the engine is running the fumes can seep into the passenger cabin, and may be a hazard to your health.
JENNYBLOOMFIELD
  • 224,000 MILES
I have a 1996 grand am 3.1. When you start it up it will idle just fine for a minute or two then it will idle up high and then idle really low and spit and sputter. To keep it from dying you have to keep your foor on the pedal. After you take off it will work itself out and will not act like that anymore, however if you shut it off for more than an hour it will do it again when you start it back up. I have replaced the map sensor, and the throttle control sensoe. I had it put back on the computer and it says the oxygen sensor had no activity even though its new as well. I got a good deal on the car and it runs really good after you get it going so I would love to know where to start.
