Have the charging system tested at most autoparts stores for free. Look for alt. Output loaded and unloaded. Even if it is charging properly you may have a bearing in the alt. Going south. Also check for proper belt tension and belt condition.
The test also includes a battery, starter test.
The ABS light is hopefully a wheel sensor that has worked loose, but you would need to get the car scanned with a chassis scanner to get the ABS fault.
Since this is an OBDI car, most likely you will have to get a trusted garage, or the dealer service scan the ABS system.
SPONSORED LINKS
Wednesday, December 24th, 2008 AT 9:35 AM
